Command Changes due to IOS Upgrade
angel-moon
Level 3
Level 3
is there a resource that can help illustrate command changes from one IOS version to the next?  Doing an upgrade and the site is several r
Seb Rupik
Hi there,
All release command references can be found here:
https://www.cisco.com/c/en/us/support/ios-nx-os-software/index.html
...If a command is being depreciated you will normally receive a warning either when you enter it on the CLI or during bootup. For this reason always test your upgrade path in a dev environment first.
cheers,
Seb.
Seb Rupik
Hi there,
cheers,
Seb.
