07-06-2017 05:28 AM - edited 03-05-2019 08:48 AM
Hi All,
In the ISR G2 series we have the "hw-module usb disable" command to disable the usb module however I am unable to find the equivalent command on ISR 4K series ( 4221 and 4321).
Could you please assist in the same.
Any other info, do give me a shout.
07-06-2017 05:33 AM
Please let me verify that. You are right is not supported for 4000 serie:
The USB Disable feature is supported only on the following Cisco ISR Generation 2 (G2) platforms:
Cisco 3925E ISR with Services Performance Engine (SPE) 250
07-06-2017 05:33 AM
Hello, thanks for the response.
However, don't you think if it had been the same command, I would've taken the toil to raise a new case in the support community ?
P.S. - Its not the same command.,
07-06-2017 05:42 AM
Yes, that is correct, please let me find more information about that.
08-27-2019 03:22 AM
06-09-2021 11:49 AM
Hello, is there an update to this question? Many folks are having the same issue, I believe.
10-20-2017 06:56 AM
Hi, did you find the command to disable or enable usb on isr 4k?
