ISR4351 Performance Boost License
colossus1611
Hi All,
Hoping there is a simple answer to this that I am missing.
We have had site bandwidth upgrade for a few customer sites recently and I successfully applied either the Performance or Boost license as per bandwidth and CIR requirement to each site without any issues.
However, I now have an ISR 4351 router that I do not see a license for under Traditional Licensing for our customer account.
How do I go about procuring it?  In the past I applied it for other platforms such as ISR4300 and ISR 4200, and had licenses available so never had to do this extra step.
Hope my question makes sense and the answer is straightforward for me to action asap.
Thank you.
6 Replies 6
balaji.bandi
If the License not available you need to buy using SKU/PAK code, if the customer already had one which is not showing, contacting the License team will be good to sort.
you can look order information :
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html#OrderingInformation
BB
Thanks Balaji. So I don’t need traditional license converted to Smart for this purpose, is that right? My understanding is that it is not needed but need clarification for our Orders team who insist that is the only way to do it.
thanks
if you are using old Code before 16.9.X i guess, you do not smart License, it still accept old License herre.
BB
colossus1611
This device is running 16.9.5 code at present.
Licenses are managed as smart licenses from Cisco IOS XE Fuji 16.9.1 and later. Right-to-Use licenses are deprecated from Cisco IOS XE Fuji 16.9.1.
BB
Nope)
Right-to-Use licenses are deprecated from Cisco IOS XE 16.10. and above)
