ip routing from ASA to router and from router to ASA
hey guys,
Finally I setup my network infrastructure of dreams :)))) but I have some question that pop-ups in my mind. Let ms first to sheme my network.
ISP modem(USE PPPOE) --> ASA --> router 2611xm --> switch 2950 --> host
Question 1: After I config all devices I put it together but when I try to access the outside I don't have access, from the host --> sw --> router --> asa --> outside, but when I connect my laptop to the ASA is working perfectly why ?
I setup the route in my case are:
on the router: ip route 172.16.2.0 255.255.255.252 172.16.2.1
on the ASA: route Home-Network 172.16.30.160 255.255.255.240 172.16.2.2 1 (also on the ASA when I set the route I use inside or out side?)
Question 2: Why when I use this config I can access outside, below is the new config (with this I can access but from what I know is not ok to use default route)
on the router: ip route 0.0.0.0 0.0.0.0 172.16.2.1
on the ASA: route Home-Network 172.16.30.160 255.255.255.240 172.16.2.2 1 also on the ASA when I set the route I use inside or out side?)
Question 3: Do you have some tips to improve my network security and QoS?
From here are the config setting on each device
Cisco Switch 2950 config
Building configuration...
Current configuration : 5639 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname S1-BETA
enable secret 5 dddddddddd
username xxxx password 7 yyyyyy
class-map match-all SERVER
  match access-group name SERVER
class-map match-all TRANSFER
  match access-group name TRANSFER
class-map match-all MANAGEMENT
  match access-group name MANAGEMENT
class-map match-all EMAIL
  match access-group name EMAIL
class-map match-all WEB
  match access-group name WEB
policy-map MARKING-TRAFFIC
  class SERVER
    police 3000000 8192 exceed-action drop
ip subnet-zero
ip dhcp snooping vlan 55
ip dhcp snooping
no ip domain-lookup
ip domain-name xxxxxx.com
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 description this is a trunk port
 switchport trunk native vlan 88
 switchport trunk allowed vlan 19,29,55,88,94
 switchport mode trunk
 switchport nonegotiate
 ip dhcp snooping trust
interface FastEthernet0/2
 switchport access vlan 55
 switchport mode access
 switchport port-security maximum 8
 spanning-tree portfast
 spanning-tree bpduguard enable
 ip dhcp snooping limit rate 6
interface FastEthernet0/3
 switchport access vlan 94
 switchport port-security maximum 2
interface FastEthernet0/4 - f0/24
 switchport access vlan 999
 shutdown
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan55
 ip address 172.16.30.162 255.255.255.240
 ip helper-address 172.16.30.161
 no ip route-cache
ip default-gateway 172.16.30.161
ip http server
ip access-list extended EMAIL
 permit tcp 172.16.30.160 0.0.0.15 any eq pop2
 permit udp 172.16.30.160 0.0.0.15 any eq 109
 permit tcp 172.16.30.160 0.0.0.15 any eq pop3
 permit udp 172.16.30.160 0.0.0.15 any eq 110
 permit tcp 172.16.30.160 0.0.0.15 any eq 995
 permit udp 172.16.30.160 0.0.0.15 any eq 995
 permit udp 172.16.30.160 0.0.0.15 any eq 25
 permit tcp 172.16.30.160 0.0.0.15 any eq smtp
 permit tcp 172.16.30.160 0.0.0.15 any eq 220
 permit udp 172.16.30.160 0.0.0.15 any eq 220
 permit tcp 172.16.30.160 0.0.0.15 any eq 143
 permit udp 172.16.30.160 0.0.0.15 any eq 143
 permit tcp 172.16.30.160 0.0.0.15 any eq 993
 permit udp 172.16.30.160 0.0.0.15 any eq 993
ip access-list extended MANAGEMENT
 permit tcp 172.16.30.160 0.0.0.15 any eq telnet
 permit udp 172.16.30.160 0.0.0.15 any eq 23
ip access-list extended SERVER
 permit ip host 172.16.30.173 host 172.16.1.2
ip access-list extended TRANSFER
 permit udp 172.16.30.160 0.0.0.15 any eq 20
 permit tcp 172.16.30.160 0.0.0.15 any eq ftp-data
 permit udp 172.16.30.160 0.0.0.15 any eq 21
 permit udp 172.16.30.160 0.0.0.15 any eq tftp
 permit tcp 172.16.30.160 0.0.0.15 any eq 69
 permit tcp 172.16.30.160 0.0.0.15 any eq 115
 permit udp 172.16.30.160 0.0.0.15 any eq 115
ip access-list extended WEB
 permit tcp 172.16.30.160 0.0.0.15 any eq www
 permit udp 172.16.30.160 0.0.0.15 any eq 80
 permit tcp 172.16.30.160 0.0.0.15 any eq 443
 permit udp 172.16.30.160 0.0.0.15 any eq 443
banner motd ^C If you are not the ADMIN get the got!!!!^C
line con 0
 exec-timeout 180 0
 login local
line vty 0 4
 exec-timeout 180 0
 login local
 transport input ssh
line vty 5 15
 exec-timeout 180 0
 login local
 transport input ssh
end
Cisco Router 2600 config
Current configuration : 3386 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
hostname R1-ALFA
boot-start-marker
boot-end-marker
security authentication failure rate 10 log
security passwords min-length 10
enable secret ggggggggggggg
aaa new-model
aaa authentication login local_auth local
aaa session-id common
no network-clock-participate slot 1
no network-clock-participate wic 0
no ip source-route
no ip gratuitous-arps
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.30.161
ip dhcp excluded-address 172.16.30.175
ip dhcp excluded-address 172.16.30.162
ip dhcp excluded-address 172.16.30.173
ip dhcp excluded-address 172.16.30.172
ip dhcp excluded-address 172.16.30.171
ip dhcp pool theAPinside
   network 172.16.30.160 255.255.255.240
   default-router 172.16.30.161
   dns-server 213.156.124.1
no ip bootp server
login block-for 180 attempts 3 within 180
username rrrrrrrrrrr password vvvvvvvvvv
archive
 log config
  hidekeys
ip ssh port xxxxxxx rotary 12
class-map match-any SERVER
class-map match-any TRANSFER
class-map match-any MANAGEMENT
class-map match-any EMAIL
class-map match-any WEB
interface FastEthernet0/0
 description The interface that talk with ASA for net
 ip address 172.16.2.2 255.255.255.252
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
 description The interface that let you to play inside
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 no ip mroute-cache
 duplex auto
 speed auto
 no cdp enable
 no mop enabled
interface FastEthernet0/1.19
 description The vlan from devices like printes (static)
 encapsulation dot1Q 19
 ip address 172.31.245.145 255.255.255.240
 no cdp enable
interface FastEthernet0/1.29
 description The vlan for something I don't know
 encapsulation dot1Q 29
 ip address 172.16.0.1 255.255.255.240
 no cdp enable
interface FastEthernet0/1.55
 description The vlan for play on net
 encapsulation dot1Q 55
 ip address 172.16.30.161 255.255.255.240
 no cdp enable
interface FastEthernet0/1.88
 shutdown
 no cdp enable
interface FastEthernet0/1.94
 description the vlan for farmvile
 encapsulation dot1Q 94
 ip address 172.16.1.1 255.255.255.240
 no cdp enable
no ip forward-protocol nd
no ip http server
ip http secure-server
ip dns server
ip access-list extended fohSSH
 deny   tcp any any eq 22
 permit tcp any any eq xxxxx
no cdp run
control-plane
banner motd ^CIf you're not the Admin get out!!^C
line con 0
 exec-timeout 180 0
 login authentication local_auth
line aux 0
line vty 0 4
 access-class fohSSH in
 rotary 12
 transport input ssh
line vty 5 9
 rotary 12
 transport input ssh
line vty 10
 rotary 12
 transport input ssh
line vty 11 15
 rotary 12
 transport input ssh
end
ASA Version 8.4(5)
interface Ethernet0/0
 description Home Outside Network
 switchport access vlan 888
interface Ethernet0/1
 description Home Inside Network
interface Vlan 8888
 description This is the outside / ISP side
 nameif outside
 security-level 0
 pppoe client vpdn group ISP-CON
 ip address pppoe setroute
interface Vlan 999
 description the Home Network
 nameif Home-Network
 security-level 100
 ip address 172.16.2.1 255.255.255.252
nat (Home-Network,outside) after-auto source dynamic any interface
vpdn group ISP-CON request dialout pppoe
vpdn group ISP-CON localname xxxxxxxxxxxxx
vpdn group ISP-CON ppp authentication pap
vpdn username ******* password ***** store-local
if yiou just want these two subnets to be natted, then indeed just add these two to your object network:
object network INSIDE_SUBNETS
subnet 172.16.1.0 255.255.255.240
subnet 172.16.30.160 255.255.255.240
nat (any,outside) dynamic interface
The additional route is just so that the ASA knows how to route back to your internal networks:
route Home-Network 172.16.1.0 255.255.255.240 172.16.2.2 1
13 Replies 13
also I want to mention when I try to connect with other devices that need an IP from my dhcp server on the router tell me is connected and when I try to access a website or something else is disconnecting me and tell that I don't have access to internet (I'm using subinterface) above are the config
the crucial part that you did not post is the full configuration of the ASA, can you post that as well ?
hey, yes
ASA Version 8.4(5)
terminal width 350
hostname Dark-Angel
domain-name xxxxx.com
enable password xfffffffffff encrypted
passwd .fffffffffffffff encrypted
names
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 shutdown
 no nameif
 no security-level
 no ip address
interface Vlan888
 nameif outside
 security-level 0
interface Vlan999
 nameif Home-Network
 security-level 100
banner motd #If you are not the admin get out#
ftp mode passive
dns server-group DefaultDNS
 domain-name xxxxxxx.com
pager lines 24
mtu outside 1500
mtu Home-Network 1500
icmp unreachable rate-limit 1 burst-size 1
icmp deny any outside
icmp permit any echo Home-Network
icmp permit any echo-reply Home-Network
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 172.16.30.173 255.255.255.255 Home-Network
http authentication-certificate Home-Network
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
no service password-recovery
telnet timeout 5
ssh 172.16.30.160 255.255.255.240 Home-Network
ssh 172.16.30.173 255.255.255.255 Home-Network
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 5
vpdn group ISP-CON localname *****
vpdn username ***** password ***** store-local
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username xxxxxxxxx password xxxxxxxxxx encrypted
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect icmp error
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:823de3cb0c0cb0434324c68eaed234234237c1
: end
it looks like you are missing some NAT and static routes. Add the below to your ASA config:
subnet 172.16.0.0 255.255.0.0
route Home-Network 172.31.245.144 255.255.255.240 172.16.2.2 1
route Home-Network 172.16.0.0 255.255.255.240 172.16.2.2 1
ok, thank you, but I have few question (the questions are because I did't told some particularly my bad sorry)
1. if I'm correct the command below is to translate all private ips to public, right ?
if yes, can i change to translate just two subnets ? the change that i made are correct ?
2. the static routes below are use to can access internet from all subnet ?
can you tell me if i'm right what i will write?
let's take the command route from ASA from what i see is a command of next-hop right ?
route = is the command
Home-Network = in my case is the inside net right ? but if I put there "outside" will translate the the outside address to inside ? my logic is correct or is faraway?
172.31.245.144 255.255.255.240 = is the subnet destination that I decided to give access to internet, right ?
172.16.2.2 1 = is the gateway of the ASA eth0/1 right ?
sorry if I ask to much, but when I understand I can go easy to config
hey,
i config ASA with
and
on the router i used
I still can't access youtube, netflix, cisco, etc
from the workstation that cannot reach YouTube, can you ping 172.16..2.1 ?
so I can ping from workstation to switch, router and ASA but from ASA back I can't
what is the IP address of the workstation ? Do you see any NAT translations in the ASA (show xlate) ?
this was the solution + a ip route on the swithc L3
Hello
on the rtr
encapsulation dot1q 88 native
no shutdown
Kind Regards
Paul
