Command to find memory in the RSP card in Cisco 7513
bjacob1976
Is there any command to check the memory available in the RSP card?
Can anyone help me out
Thanks in Advance,
Beno
Danilo Dy
When you say RSP card, you mean the Flash card?
For RSP1 and RSP2 the command is "show slot0:"
For RSP4/4+, RSP8, and RSP16 the command is "show slot0:" and "show slot1:"
Other than the Flash card, the other types of memory in RSP are;
DRAM Memory SIMM and FLASH SIMM for RSP1 and RSP2
DRAM Memory DIMM and FLASH SIMM for RSP4/4+, RSP8, and RSP16
