Conditional debuggin on ASR1k - IOX-XE 3.8
cisco_geek
Dear All,
I'm trying to run a diebug ip packet detailed with an access-list but it's not working! Nothing is shown!
The weird part is that the debug ip packet detail is not working as well without the access-list, and it only works when the traffic is locally originated from the router only!
Is it an IOS bug? or do I miss something
amabdelh
Can you turn off the cef on that particular interface?
Yes I did so, because I assumed that the ASR might not debug the CEF switched packets, but no use.
Debugging is still working only for the locally generated icmp echo requests.
Is there anyone
can you show me the logging configuration on your router? and send the show logg
