IOS XE upgrade on 4500-x
johnelliot6
Level 2
Level 2
Have a new 4500-x (Comes with IPBase enabled), but I see only universal image is available for download  (Which I understand has "all" features)...assume it is safe to use the latest universal image on 4500-x and the IPBase license will be automatically applied?
I also see there is a new rom upgrade available - Is this the correct procedure to follow:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_24829.html#wp178803
Should I be doing the rom upgrade first?
Cheers.
Leo Laohoo
1.  License - Your license (IP Base) will remain the same.  Besides, you can't go any LOWER than IP Base.
2.  Bootstrap - Copy the IOS into your 4500X but DO NOT reboot the appliance.  Run the bootstrap upgrade and then you'll be given a "y/n" prompt.  Choose "y" and the bootstrap will be installed and the appliance will reboot.
Read the Release Notes first so you'll know what caveats are addressed and pending.
Hi what is the upgrade process?
