config int. to use ISP DHCP
shanemcanuff
I have a 2600 router and want to connect it to my ISP, how do I config.. the interface to use the ISP DHCP?
If all you need is an IP address from your ISP on your router then yes.
Mark
Mark Yeates
Level 7
Level 7
Shane,
You should configure the port connected to your ISP with the following interface command (ip address dhcp".
HTH,
Mark
and that is the only command I should put on the interface?
Mark
