configuration NAT overload for ASA 5525
MohammadSalih
hi every one ,
i want to configure NAT over load
i have one public ip address 37.x.x.x
and pool of private ip addresses 70.70.x.x
when i configure natting by typing
nat (inside,outside) soure (static or dynamic) ,
there is no PAT configuration , because i want every private IPs share one public ip.
22 Replies 22
sorry I make double check your config you have two IN and one OUT, where is the config of other OUT interface??
hi
i have 2 IN and 2 OUT
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 37.X.X.194 255.255.255.248
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 70.70.2.1 255.255.255.0
nameif inside
security-level 100
ip address 70.70.3.1 255.255.255.0
object network public_LAN1
host 37.X.X.195
object network public_LAN2
host 37.X.X.196
object-group network private_LAN1
network-object 70.70.2.0 255.255.255.0
object-group network private_LAN2
network-object 70.70.3.0 255.255.255.0
(just missing the NAT/PAT command)
you meaning two public IP and one OUT interface ? am I right ?
yes
and each private goes to each public
70.70.2.0/24 (private) go to 37.X.X.195
70.70.3.0/24 (private) go to 37.X.X.196
Hello
clear configure object
clear configure object-group
nat (inside,outside) after-auto source dynamic any interface
route  outside 0 0 37.X.X.X
Kind Regards
Paul
hi dear,
what do you mean by clear?
you mean remove configuration form the objects?
Hello
Did you try the configuration I previously posted (see below) ?
Can you post the output from the following traces:
packet-tracer input inside tcp 70.70.2.x 12345 8.8.8.8 80
packet-tracer input inside tcp 70.70.3.x 12345 8.8.8.8 80
Lastly what you have explained from your OP the below should work
route outside 0 0 37.X.X.<-- default route and nexthop)
object network Inside_1
Subnet 70.70.2.0 255.255.255.0
object network outside1
host 37.X.X.195
object network Inside_2
subnet 70.70.3.0 255.255.255.0
object network outside2
host 37.X.X.196
nat (inside,outside)  1source dynamic Inside_1 outside1
nat (inside,outside)  2 source dynamic Inside_2 outside2
Kind Regards
Paul
this lab I run for you, check how I config the NAT overload using two public IP and one OUT interface.
