configuration NAT overload for ASA 5525
MohammadSalih
hi every one ,
i want to configure NAT over load
i have one public ip address 37.x.x.x
and pool of private ip addresses 70.70.x.x
when i configure natting by typing
nat (inside,outside) soure (static or dynamic) ,
there is no PAT configuration , because i want every private IPs share one public ip.
22 Replies 22
nat (inside,outside) source dynamic any interface <<<- I use this for NAT overload
Hello @MHM Cisco World
FYI
nat (inside,outside) source dynamic any interface =  Section 1
nat (inside,outside) after-auto source dynamic any interface  = Section 3
Kind Regards
Paul
both are NAT overload
after-auto just change the orde of NAT not change the NAT type.
Hello
What im trying to allude to is you wouldn't want dynamic PAT (overload) to be in section 1, its a catch all statement as such if you need to append additional statements then you would have to re-order the NAT to accommodate , so would say its recommended to use section 3.
Kind Regards
Paul
post the full running configuration (sh run) of your ASA.
thanks for replying
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 37.X.X.194 255.255.255.248
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 70.70.2.1 255.255.255.0
nameif inside
security-level 100
ip address 70.70.3.1 255.255.255.0
object network public_LAN1
host 37.X.X.195
object network public_LAN2
host 37.X.X.196
object-group network private_LAN1
network-object 70.70.2.0 255.255.255.0
object-group network private_LAN2
network-object 70.70.3.0 255.255.255.0
(just missing the NAT/PAT command)
Hello
ASA NAT/PAT you can apply it two ways:
Manual NAT (globally) or  Auto NAT (under an object)
It also has 3 sections (Default 1)
Manual NAT can be set in Section 1 or 3 (after auto)
Auto NAT = Section 2.
These sections are checked in order (1,2,3)
Manual
Auto
After Auto
Lastly in each section the nat rules are ordered sequentially just like within an access-list.
Can you post the following.
sh run nat
sh nat
sh run object
sh run object-group
sh run access-list
sh run access-group
Also perform a packet tracer and post the output.
packet-tracer input INSIDE tcp < lan ip> 12345 <internet ip> 80
Kind Regards
Paul
thanks for replying
nameif outside
security-level 0
nameif inside
security-level 100
nameif inside
security-level 100
host 37.X.X.195
host 37.X.X.196
then just add NAT as I mention above.
good luck friend
thanks alot for help,
i will apply this command (nat (inside,outside) source dynamic any interface) as you mentioned me,
but how to Control NATTING transluations
over more than one public?
i want 70.70.2.0/24 goes to 37.X.X.195
and
70.70.3.0/24 goes to 37.X.X.196
how can i deploy it in nat command?
I will share lab with you tonight.
thanks alot .
Hello
and
object network Inside_1
Subnet 70.70.2.0 255.255.255.0
object network outside1
host 37.X.X.195
object network Inside_2
subnet 70.70.2.0 255.255.255.0
object network outside2
host 37.X.X.196
nat (inside,outside)  1source dynamic Inside_1 outside1
nat (inside,outside)  2 source dynamic Inside_2 outside2
Kind Regards
Paul
i will try it.
thanks very much.
