Configure Cisco 1841 fast ethernet to WAN and LAN link
Hi guys,
I am trying to install this new Cisco 1841 as a replacement to Cisco 877, site just recently upgraded to fiber optics so we need to replace the router to Cisco 1841. There is a singtel router before the cisco router...
Do I just connect the WAN cable to the fast ethernet port? then the LAN cable to another fast ethernet port?
and set static ip?
sample:
interface Fa0/0
description WAN LINK
ip address 201.222.222.174 255.255.255.0
duplex auto
speed auto
interface Fa0/1
description LAN LINK
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
ip router 0.0.0.0 0.0.0.0 201.222.222.174
Is this the only thing I need to do?
Really need your help.
Jenna
6 Replies 6
ajay chauhan
Level 7
Level 7
Frist of all default gateway can not be same as interface IP need to identify next hop. Then it actually depend upon what you are trying to do ,if users need internet access then NAT will be there. For security you might need to configure ACL .
For management you need to configure SSH/ VTY and rest of the things.
So far cabling is concern yes one port will go to WAN (SP) equipment and one port of router will go to switch where users are connected but all depends.
Untill unless you do not tell what will be the goal helping would be difficult.
Ajay
Thanks for your response Ajay.
Sorry, my mistake on the sample config, let me correct this:
interface Fa0/0
duplex auto
speed auto
interface Fa0/1
ip address 58.xx.xx.1 255.255.255.0
duplex auto
speed auto
ip router 0.0.0.0 0.0.0.0 201.222.222.173
Also, their LAN IP should be accessible over the internet as the other branch office need to access one of the terminal server (58.xx.xx.6). I tried to compare the config on the old router (cisco 877) but there is no NAT or ACL configured, maybe because there is a firewall behind the router.
Here is the config on the old router:
Building configuration...
Current configuration : 959 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$3ELz$yf9vgIgb9IFt4d/qENIUh0
no aaa new-model
dot11 syslog
ip cef
--More--         !
archive
log config
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 203.222.222.174 255.255.255.252
pvc 8/35
  encapsulation aal5snap
--More--         !
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 58.xx.xx.1 255.255.255.240
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 203.222.222.173
no ip http server
no ip http secure-server
So I guess I only need to configure the WAN interface and LAN interface then static route?
Thanks.
Since you are using 10.10.10.1 255.255.255.0 address your need to NAT it. You don't need to NAT in your other location since both inside and outside IPs are public.  Other then that your config is ok.  Can you ping the SP's router from your router?
Hi Jenna,
Try to double check your interface's subnet mask (comparing to 877):
interface Fa0/0
ip address 201.222.222.174 255.255.255.252
interface Fa0/1
As suggested, perform ping tests towards the ISP router and your firewall, which I would assume is doing NAT for your 10.1.1.0/24 subnet.
Hi all good guy!!
I have issue as Forbes. So, I want to know which more rule that can me access to internet?
For me I am already create default route but still cannot access.
Please help me!
If you are using private ip addresses then you need to set NATing in order to access the internet.
If possible could you please send the config of the router, so it will help us to find the problem,
Vishal--
