Cisco ISR 4331 not booting normally and not configured
razeev rohilla
Hi All,
when i tried configure Cisco ISR 4331 Router it hanged 2 twice and i restart it, after restart, Router Booting with image ISR Software (X86_64_LINUX_IOSD-UCMK9-M), Version 16.9.2, RELEASE SOFTWARE (fc1). Instead of ISR Software (X86_64_LINUX_IOSD-UNIVERSLAK9-M), Version 16.6.6 image. below is the outcome. Please help me to understand
tunnel Open a tunnel connection
ucse UCSE server
udptn Open an udptn connection
undebug Disable debugging functions (see also 'debug')
upgrade Upgrade commands
utd Unified Threat Defense commands
verify Verify a file
voice Voice Commands
vtp Configure global VTP state
where List active connections
which-route Do OSI route table lookup and display results
who who
write Write running configuration to memory, network, or
terminal
xconnect Xconnect EXEC commands
xprofile Profile operations
xremote Enter XRemote mode
Router# reload
Proceed with reload? [confirm]
*Jun 5 14:39:45.687: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Jun 5 14:40:16.971: %PMA
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(3r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4331/K9 platform with 8388608 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
Located isr4300-ucmk9.16.9.2.SPA.bin
Package header rev 1 structure detected
IsoSize = 421446537
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated CFE7CA01:1CCB97D4:03D19C9A:FBD47C48:0FBFF2D7
expected CFE7CA01:1CCB97D4:03D19C9A:FBD47C48:0FBFF2D7
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
DCUBE_SUBSYS Initialized
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [], ISR Software (X86_64_LINUX_IOSD-UCMK9-M), Version 16.9.2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Sat 08-Sep-18 02:36 by cedge-sw-dev
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
% Failed to initialize nvram
% Failed to initialize backup nvram
cisco ISR4331/K9 (1RU) processor with 3836304K/6147K bytes of memory.
Processor board ID FDO2304A1TA
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6598655K bytes of flash memory at bootflash:.
Press RETURN to get started!
*Jun 5 14:45:35.912: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 14:45:35.982: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 14:45:36.267: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 14:45:37.253: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 14:45:38.183: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 14:45:39.100: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 14:45:39.124: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 14:45:45.426: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277123741588776
*Jun 5 14:45:50.102: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 14:45:50.616: in NSH init
*Jun 5 14:45:50.684: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 14:45:51.779: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 14:45:51.796: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 14:45:51.797: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 14:45:51.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 14:45:51.812: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 14:45:52.342: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 14:45:52.801: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 14:45:52.801: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 14:45:53.877: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 5 14:45:53.932: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 14:45:53.932: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 14:42:45.074: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 14:45:39.459: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 14:45:57.707: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Jun 5 14:45:57.720: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 14:45:57.734: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 14:45:57.739: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 14:45:57.739: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 14:45:57.777: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 5 14:45:57.777: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 14:45:57.781: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 14:45:57.781: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 14:45:57.847: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 14:45:58.024: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 14:45:58.024: SDWAN INFO: SDWAN system init done
*Jun 5 14:45:58.135: yang-infra: Auto enable netconf-yang
*Jun 5 14:45:58.172: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 5 14:45:58.673: yang-infra: netconf-yang server has been notified to start
*Jun 5 14:46:00.990: %SYS-5-RESTART: System restarted --
*Jun 5 14:46:04.409: %SYS-6-BOOTTIME: Time taken to reboot after reload = 379 seconds
*Jun 5 14:46:09.373: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 14:46:09.382: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-2482764321 to specify TP-self-signed-2482764321 keypair usage% Generating 2048 bit RSA keys, keys will be non-exportable...
*Jun 5 14:46:10.773: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 14:46:10.773: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 14:46:09.621: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 3405 in vpn 65534
*Jun 5 14:46:11.615: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 14:46:11.664: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
[OK] (elapsed time was 3 seconds)
*Jun 5 14:46:14.426: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 14:46:14.428: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 14:46:14.492: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 5 14:46:14.671: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
*Jun 5 14:46:28.806: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 14:46:29.215: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:8021 User:a has connected.
*Jun 5 14:46:32.978: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 5 14:46:33.090: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 5 14:46:33.108: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing to convert
*Jun 5 14:46:33.117: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 14:46:34.967: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 5 14:46:35.080: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 5 14:46:35.098: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jun 5 14:46:35.316: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:3663 User:NETCONF has connected.
*Jun 5 14:46:37.004: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 8878 in vpn 0
*Jun 5 14:46:37.006: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 8879 in vpn 0
*Jun 5 14:46:37.008: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 8880 in vpn 0
*Jun 5 14:46:37.012: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 8881 in vpn 0
*Jun 5 14:46:37.014: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 8882 in vpn 0
*Jun 5 14:46:37.017: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 8883 in vpn 0
*Jun 5 14:46:37.431: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 14:46:37.673: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 14:46:37.805: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 14:46:37.834: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 14:46:38.172: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 5 14:46:38.814: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f107d235500 p_ftm 0x9296f0
*Jun 5 14:46:39.778: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 14:46:39.784: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 14:46:41.775: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 5 14:46:53.337: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 14:46:57.737: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 14:47:11.051: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 14:47:06.985: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 14:47:15.017: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 14:47:22.401: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 14:47:22.669: SDWAN INFO: PNP start, status: success
*Jun 5 14:47:22.581: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 5 14:47:22.664: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
User Access Verification
Username:
% Username: timeout expired!
Username: neteng
Password:
% Login invalid
Username:
Router con0 is now available
Press RETURN to get started.
Username:
Username:
Last reset cause: PowerOn
Failed to find bootable image on device bootflash:
autoboot: boot failed, restarting...
Resetting .......
rommon 1 > ?
alias set and display aliases command
boot boot up an external process
confreg configuration register utility
dev list the device table
dir list files in file system
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
showmon display currently selected ROM monitor
sync write monitor environment to NVRAM
token display board's unique token identifier
unalias unset an alias
unset unset a monitor variable
rommon 2 > confreg 0x2142
rommon 3 > reset
Resetting .......
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
*Jun 5 15:08:00.860: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:08:00.931: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 15:08:01.216: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 15:08:02.200: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 15:08:03.131: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 15:08:04.050: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:08:04.074: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:08:10.602: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277165542067496
*Jun 5 15:08:15.282: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 15:08:15.790: in NSH init
*Jun 5 15:08:15.851: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 15:08:16.947: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 15:08:16.964: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 15:08:16.965: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 15:08:16.979: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 15:08:16.980: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 15:08:17.508: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 15:08:17.990: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 15:08:17.990: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 15:08:17.991: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 15:08:19.059: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table- id 0x1E000001
*Jun 5 15:08:19.116: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 15:05:07.085: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 15:05:51.551: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.551: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=10 addr=0x50 status=0x0
*Jun 5 15:05:51.609: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.609: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=11 addr=0x50 status=0x0
*Jun 5 15:05:51.667: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.667: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=12 addr=0x50 status=0x0
*Jun 5 15:05:51.725: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.725: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=13 addr=0x50 status=0x0
*Jun 5 15:05:51.782: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:05:51.782: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=14 addr=0x50 status=0x0
*Jun 5 15:08:04.915: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 15:08:22.319: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setti ng.
*Jun 5 15:08:22.333: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 15:08:22.348: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:08:22.353: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 15:08:22.353: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 15:08:22.389: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 5 15:08:22.389: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 15:08:22.393: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 15:08:22.393: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 15:08:22.457: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 15:08:22.642: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 15:08:22.642: SDWAN INFO: SDWAN system init done
*Jun 5 15:08:22.755: yang-infra: Auto enable netconf-yang
*Jun 5 15:08:22.799: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 5 15:08:23.301: yang-infra: netconf-yang server has been notified to start
*Jun 5 15:08:24.861: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 15:08:24.869: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 5 15:08:26.319: %SYS-5-RESTART: System restarted --
*Jun 5 15:08:25.427: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 372 in vpn 65534
CRYPTO_PKI: setting trustpoint policy for TP-self-signed-2482764321 to specify TP-self-signed-2482764321 keypair usage% Generating 204 8 bit RSA keys, keys will be non-exportable...
*Jun 5 15:08:35.883: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:08:35.883: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:08:36.707: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 15:08:36.796: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensu re system clock is configured/updated.
*Jun 5 15:08:39.756: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 15:08:39.758: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 15:08:39.844: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 5 15:08:40.001: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
*Jun 5 15:08:56.297: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 15:08:56.501: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:2026 User:a has connec ted.
*Jun 5 15:08:57.254: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 5 15:08:56.548: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 7206 in vpn 0
*Jun 5 15:08:56.550: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 7207 in vpn 0
*Jun 5 15:08:56.552: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 7208 in vpn 0
*Jun 5 15:08:56.554: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 7210 in vpn 0
*Jun 5 15:08:56.556: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 7211 in vpn 0
*Jun 5 15:08:56.558: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 7213 in vpn 0
*Jun 5 15:08:57.183: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 15:08:57.211: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 15:08:57.288: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 15:08:57.440: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 15:08:57.709: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128% , latency = 2147483647 ms
*Jun 5 15:08:58.078: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 5 15:08:58.342: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing to convert
*Jun 5 15:08:58.415: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 15:08:58.341: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f8fdae35500 p_ftm 0x92 96f0
*Jun 5 15:08:59.304: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 5 15:08:59.489: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:08:59.492: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:08:59.751: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 5 15:09:00.448: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed state to down
*Jun 5 15:09:01.579: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 5 15:09:06.010: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:5544 User:NETCONF has co nnected.
*Jun 5 15:09:22.417: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 15:09:23.108: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 15:09:28.993: %DMI-3-CDB_START_FAIL: R0/0: syncfd: Could not start session to read configuration from the DMI data store locke d (10): Could not acquire lock.
*Jun 5 15:09:29.188: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 15:09:34.396: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 15:09:39.265: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 15:09:45.391: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 15:09:45.512: SDWAN INFO: PNP start, status: success
*Jun 5 15:09:45.490: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 5 15:09:45.505: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Username: Cisco
Password:
% Login invalid
Username: neteng
Password:
% Login invalid
Username: Cisco
Password:
% Login invalid
Username: cisco
Password:
% Login invalid
Username: cisco
Password:
% Login invalid
Username: Cisco
Password:
% Login invalid
Username: NETCONG
Password:
% Login invalid
Username:
Resetting .......
rommon 1 > ?
reset system reset
rommon 2 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 3 > confreg 0x2142
rommon 4 > unset
usage: unset [name=value]
rommon 5 > boot ?
unable to open ? (14)
rommon 6 > boot
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
*Jun 5 15:29:12.582: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:29:12.652: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 15:29:12.713: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 15:29:13.698: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 15:29:14.629: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 15:29:15.545: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:29:15.571: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:29:22.080: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223277978913439016
*Jun 5 15:29:26.762: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 15:29:27.284: in NSH init
*Jun 5 15:29:27.346: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 15:29:28.444: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 15:29:28.461: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 15:29:28.462: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 15:29:28.476: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 15:29:28.477: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 15:29:29.010: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 15:29:29.520: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 15:29:29.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 15:29:29.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 15:29:30.688: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 5 15:29:30.746: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 15:26:19.075: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 15:27:03.760: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.760: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=10 addr=0x50 status=0x0
*Jun 5 15:27:03.817: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.817: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=11 addr=0x50 status=0x0
*Jun 5 15:27:03.875: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.875: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=12 addr=0x50 status=0x0
*Jun 5 15:27:03.933: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.933: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=13 addr=0x50 status=0x0
*Jun 5 15:27:03.991: %IOSXE-3-PLATFORM: R0/0: kernel: dash_c2w_op_done: I2C Master time out: status register - 0x0
*Jun 5 15:27:03.991: %IOSXE-3-PLATFORM: R0/0: kernel: dash_i2c_xfer: I2C Master Error master=14 addr=0x50 status=0x0
*Jun 5 15:29:16.536: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 15:29:33.683: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Jun 5 15:29:33.699: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 15:29:33.714: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:29:33.719: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 15:29:33.719: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 15:29:33.756: %IOSXE_OIR-6-INSCARD: Card (cc) inser
Router>
Router>
Router>
Router>
Router>ted in slot 0
*Jun 5 15:29:33.756: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 15:29:33.759: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 15:29:33.759: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 15:29:33.827: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 15:29:34.024: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 15:29:34.024: SDWAN INFO: SDWAN system init done
*Jun 5 15:29:34.119: yang-infra: Auto enable netconf-yang
*Jun 5 15:29:34.154: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Jun 5 15:29:34.677: yang-infra: netconf-yang server has been notified to start
*Jun 5 15:29:35.922: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 15:29:35.929: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 5 15:29:35.966: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 32524 in vpn 65534
*Jun 5 15:29:39.100: %SYS-5-RESTART: System restarted --
Router>
Router>
*Jun 5 15:29:47.443: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:29:47.443: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:29:48.400: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 15:29:48.450: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
Router>
Router>
[OK] (elapsed time was 8 seconds)
*Jun 5 15:29:56.289: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 15:29:56.290: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 15:29:56.390: yang-infra: ERROR: Failed to create a new self-signed trustpointen
*Jun 5 15:29:56.592: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
Router#?
Exec commands:
access-profile Apply user-profile to interface
alps ALPS exec commands
app-hosting Application hosting
appnav IOS Wide Area Application Services
archive manage archive files
attach Connect to a module's console
audio-prompt load ivr prompt
authentication Authentication options for eEdge
auto Exec level Automation
beep Blocks Extensible Exchange Protocol commands
bfe For manual emergency modes setting
bulkstat Bulkstat exec commands
call Voice call
call-home Call-Home commands
ccm-manager Call Manager Application exec commands
cd Change current directory
clear Reset functions
clock Manage the system clock
cns CNS agents
config-transaction config transaction
configure Enter configuration mode
connect Open a terminal connection
copy Copy from one file to another
credential load the credential info from file system
crypto Encryption related commands.
cts Cisco Trusted Security Exec Commands
debug Debugging functions (see also 'undebug')
delete Delete a file
diagnostic Diagnostic commands
dir List files on a filesystem
disable Turn off privileged commands
disconnect Disconnect an existing network connection
do-exec Mode-independent "do-exec" prefix support
dot1x IEEE 802.1X Exec Commands
eap EAP Exec Commands
emadmin Extension Mobility Commands
enable Turn on privileged commands
erase Erase a filesystem
ethernet Ethernet parameters
event Event related commands
exit Exit from the EXEC
factory-reset Factory Reset command
file-acct File mode accounting exec command
flush File mode accounting flush options
format Format a filesystem
--More--
*Jun 5 15:30:07.006: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 5941 in vpn 0
*Jun 5 15:30:07.008: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 5943 in vpn 0
*Jun 5 15:30:07.011: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 5944 in vpn 0
*Jun 5 15:30:07.013: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 5946 in vpn 0
*Jun 5 15:30:07.015: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 594 fsck Filesystem check
--More--
*Jun 5 15:30:07.018: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 5948 in vpn 0
*Jun 5 15:30:07.536: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 15:30:07.602: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 15:30:07.679: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 15:30:07.757: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 15:30:08.204: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 5 15:30:09.242: AUTH-FEAT-BC-EVENT: [Gi0/0/0] Nothing to convert
*Jun 5 15:30:08.939: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f2315c35500 p_ftm 0x9296f0
*Jun 5 15:30:09.872: AUTH-FEAT-BC-EVENT: [Gi0/0/1] Nothing to convert
*Jun 5 15:30:10.081: AUTH-FEAT-BC-EVENT: [Gi0/0/2] Nothing help Description of the interactive help system
hunt-group hunt group exec command
--More--
*Jun 5 15:30:10.099: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 15:30:10.170: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:30:10.171: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:30:11.229: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Jun 5 15:30:11.991: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Jun 5 15:30:12.120: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/2, changed sta hw-module Apply command to specific hardware component
if-mgr IF-MGR operations
--More--
*Jun 5 15:30:12.311: SDWAN INFO: application database sync to FPM: record-count 142 install Install command
ip IP SLA Exec Command
isdn Run an ISDN EXEC command on an ISDN interface
issu issu commands
l2vpn Layer2 VPN commands
lat Open a lat connection
license License information
lig LISP Internet Groper
lock Lock the terminal
logging Handles logging operations
login Log in as a particular user
logout Exit from the EXEC
maintenance Maintenance mode
microcode microcode commands
mkdir Create new directory
mlacp mLACP EXEC commands
monitor Monitoring different system events
more Display the contents of a file
mpls MPLS commands
mrinfo Request neighbor and version information from a multicast
router
mrm IP Multicast Routing Monitor Test
mstat Show statistics after multiple multicast traceroutes
mtrace Trace reverse multicast path from destination to source
name-connection Name an existing network connection
ncia Start/Stop NCIA Server
network-clock Network clock
no Disable debugging functions
pad Open a X.29 PAD connection
partition Partition disk
ping Send echo messages
pnpa PnP agent
ppp Start IETF Point-to-Point Protocol (PPP)
pwd Display current working directory
redundancy Redundancy Facility (RF) exec commands
release Release a resource
reload Halt and perform a cold restart
rename Rename a file
renew Renew a resource
request Request an action
restart Restart Connection/Interface
resume Resume an active network connection
rlogin Open an rlogin connection
rmdir Remove existing directory
routing-context Routing Context
rsh Execute a remote command
sbc Session Border Controller
sdlc Send SDLC test frames
send Send a message to other tty lines
service IOS integrated service enablement
set Set system parameter (not config)
setup Run the SETUP command facility
sga-internal Cisco Trusted Security Exec Commands
show Show running system information
slip Start Serial-line IP (SLIP)
snmp snmp commands
spec-file format spec file commands
ssh Open a secure shell client connection
start-chat Start a chat-script on a line
systat Display information about terminal lines
tarp TARP (Target ID Resolution Protocol) commands
tclquit Quit Tool Command Language shell
tclsh Tool Command Language shell
telnet Open a telnet connection
terminal Set terminal line parameters
test Test subsystems, memory, and interfaces
tn3270 Open a tn3270 connection
traceroute Trace route to destination
ucse UCSE server
--More--
*Jun 5 15:30:16.635: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 15:30:16.844: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:8411 User:a has who who
terminal
x28 Become an X.28 PAD
x3 Set X.3 parameters on PAD
Router#
Router#
Router#
*Jun 5 15:30:22.265: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:6533 User:NETCONF has connected.conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
*Jun 5 15:30:36.073: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 15:30:36.125: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 15:30:46.103: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 15:30:41.975: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 15:30:52.550: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 15:30:54.658: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 15:30:54.943: SDWAN INFO: PNP start, status: success
*Jun 5 15:30:54.866: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
*Jun 5 15:30:54.943: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Router(config)#hostname r-a.s04811.in
r-a.s04811.in(config)#username neteng secret cisco@123
r-a.s04811.in(config)#enable secre
r-a.s04811.in(config)#enable secret cisco@123
r-a.s04811.in(config)#do wr
This command is not supported
r-a.s04811.in#
r-a.s04811.in(config)#^Z
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
*Jun 5 15:32:12.354: %SYS-5-CONFIG_I: Configured from console by consolewr
r-a.s04811.in#
r-a.s04811.in#wr
r-a.s04811.in#
r-a.s04811.in#conf t
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#?
Exec commands:
call Voice call
cns CNS agents
issu issu commands
mpls MPLS commands
router
pnpa PnP agent
snmp snmp commands
ucse UCSE server
who who
terminal
r-a.s04811.in#conf
r-a.s04811.in#configur
r-a.s04811.in#configure ter
r-a.s04811.in#configure terminal
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#?
Exec commands:
call Voice call
cns CNS agents
issu issu commands
mpls MPLS commands
router
pnpa PnP agent
snmp snmp commands
ucse UCSE server
who who
terminal
r-a.s04811.in#$
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#
r-a.s04811.in#fa
r-a.s04811.in#factory-reset ?
all All factory reset operations
r-a.s04811.in#factory-reset all
The factory reset operation is irreversible for all operations. Are you sure? [confirm]
This operation may take 20 minutes or more. Please do not power cycle.
*Jun 5 15:35:57.224: %SYS-5-RELOAD: Reload requested by Exec. Reload Reason: Factory Reset.Jun 5 15:36:26.961: %PMAN
Both copies of Nvram are corrupted.
Warning: monitor Nvram area is corrupt ... using default values
Confreg is corrupted, using default 8000
Key Sectors:(Primary, GOOD),(Backup,GOOD),(Revocation,GOOD)
Size of Primary = 2288 Backup = 2288 Revocation = 288
RSA Self Test Passed
Expected hash:
DDAF35A193617ABACC417349AE204131
12E6FA4E89A97EA20A9EEEE64B55D39A
2192992A274FC1A836BA3C23A3FEEBBD
454D4423643CE80E2A9AC94FA54CA49F
Obtained hash:
Sha512 Self Test Passed
rommon 1 > ?
reset system reset
rommon 3 > reset
Resetting .......
IsoSize = 421446537
Image validated
Cisco Systems, Inc.
Software feature.
*Jun 5 15:47:56.881: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:47:56.978: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = No valid license found
*Jun 5 15:47:57.263: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Jun 5 15:47:58.247: %IOSXE_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Jun 5 15:47:59.178: %IOSXE_RP_NV-3-BACKUP_NV_ACCESS_FAIL: Initial read of backup NVRAM contents failed
*Jun 5 15:48:00.320: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:48:00.342: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Jun 5 15:48:06.749: %GENERIC_SUBBLOCK-2-LATE_REGISTER: Late registration of GSB type pbr_color_sb, with id -9223278127895043368
*Jun 5 15:48:11.453: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jun 5 15:48:11.971: in NSH init
*Jun 5 15:48:12.033: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Jun 5 15:48:13.361: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Jun 5 15:48:13.378: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Jun 5 15:48:13.379: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jun 5 15:48:13.396: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Jun 5 15:48:13.396: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Jun 5 15:48:13.915: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Jun 5 15:48:14.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Jun 5 15:48:14.395: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Jun 5 15:48:14.396: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Jun 5 15:48:15.456: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Jun 5 15:48:15.516: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Jun 5 15:45:05.079: %IOSXE-3-PLATFORM: R0/0: kernel: dmi: Firmware registration failed.
*Jun 5 15:45:55.130: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda7): error: can't find an ext2 filesystem on dev sda7.
*Jun 5 15:45:55.348: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda8): error: can't find an ext2 filesystem on dev sda8.
*Jun 5 15:45:55.578: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda9): error: can't find an ext2 filesystem on dev sda9.
*Jun 5 15:45:55.855: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda10): error: can't find an ext2 filesystem on dev sda10.
*Jun 5 15:45:56.097: %IOSXE-3-PLATFORM: R0/0: kernel: EXT2-fs (sda6): error: can't find an ext2 filesystem on dev sda6.
*Jun 5 15:48:00.795: %CMLIB-3-THROUGHPUT_VALUE_SETUP_FAILED: R0/0: cmand: Throughput license found, throughput set to 14700000 kbps. Error: Invalid argument
*Jun 5 15:48:18.729: %SYS-6-STARTUP_CONFIG_IGNORED: System startup configuration is ignored based on the configuration register setting.
*Jun 5 15:48:18.744: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Jun 5 15:48:18.745: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:48:18.749: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Jun 5 15:48:18.749: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Jun 5 15:48:18.784: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Jun 5 15:48:18.785: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Jun 5 15:48:18.789: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Jun 5 15:48:18.789: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Jun 5 15:48:18.849: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Jun 5 15:48:19.029: SDWAN INFO: Interface = GigabitEthernet0 mgmt
*Jun 5 15:48:19.029: SDWAN INFO: SDWAN system init done
*Jun 5 15:48:19.139: yang-infra: Auto enable netconf-yang
*Jun 5 15:48:19.230: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base
Router>
Router>
Router>was enabled by Default
*Jun 5 15:48:19.732: yang-infra: netconf-yang server has been notified to start
*Jun 5 15:48:22.063: %SYS-5-RESTART: System restarted --
*Jun 5 15:48:31.419: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200050: R0/0: SYSMGR: System status blinking green (reason: Coming up)
*Jun 5 15:48:31.427: %Cisco-SDWAN-Router-SYSMGR-5-NTCE-200042: R0/0: SYSMGR: Created shared memory vconfd_shared_region
*Jun 5 15:48:31.428: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon confd @ pid 3533 in vpn 65534
*Jun 5 15:48:32.051: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:48:32.051: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 5 15:48:33.046: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Jun 5 15:48:33.095: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI timers have not been initialized due to non-authoritative system clock. Ensure system clock is configured/updated.
[OK] (elapsed time was 2 seconds)
*Jun 5 15:48:35.031: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321 has been generated or imported
*Jun 5 15:48:35.033: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun 5 15:48:35.153: yang-infra: ERROR: Failed to create a new self-signed trustpoint
*Jun 5 15:48:35.325: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-2482764321.server has been generated or imported
Router>en
Router#c
*Jun 5 15:48:46.639: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Vty was enabled by Platform
*Jun 5 15:48:47.043: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.syncfd Host:Router ID:2268 User:a has connected.onf t
Router(config)#
*Jun 5 15:48:53.501: new extended attributes received from iomd(slot 0 bay 0 board 0)do sh
*Jun 5 15:48:53.778: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Jun 5 15:48:53.780: %IOSXE_OIR-6-SOFT_RELOADSPA: SPA(ISR4331-3x1GE) reloaded on subslot 0/0
*Jun 5 15:48:53.780: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Jun 5 15:48:54.903: %ONEP_BASE-6-CONNECT: [Element]: ONEP session Application:com.cisco.nesd Host:Router ID:5752 User:NETCONF has connected.ver
Cisco IOS XE Software, Version 16.9.2
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 1 minute
Uptime for this control processor is 3 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-ucmk9.16.9.2.SPA.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
--More--
*Jun 5 15:48:59.007: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon cfgmgr @ pid 9552 in vpn 0
*Jun 5 15:48:59.009: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon fpmd @ pid 9553 in vpn 0
*Jun 5 15:48:59.012: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ftmd @ pid 9555 in vpn 0
*Jun 5 15:48:59.015: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ompd @ pid 9556 in vpn 0
*Jun 5 15:48:59.017: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon ttmd @ pid 9557 in vpn 0
*Jun 5 15:48:59.020: %Cisco-SDWAN-Router-SYSMGR-6-INFO-200017: R0/0: SYSMGR: Started daemon vdaemon @ pid 9558 in vpn 0
*Jun 5 15:48:59.556: %Cisco-SDWAN-Router-TTMD-6-INFO-1200001: R0/0: TTMD: Starting
*Jun 5 15:48:59.747: %Cisco-SDWAN-Router-OMPD-5-NTCE-400001: R0/0: OMPD: Starting
*Jun 5 15:48:59.787: %Cisco-SDWAN-Router-CFGMGR-6-INFO-300001: R0/0: CFGMGR: Starting
*Jun 5 15:48:59.788: %Cisco-SDWAN-Router-FPMD-6-INFO-1100001: R0/0: FPMD: Starting
*Jun 5 15:49:00.341: %Cisco-SDWAN-Router-FTMD-6-INFO-1000020: R0/0: FTMD: SLA class '__all_tunnels__' added at index '0': loss = 128%, latency = 2147483647 ms
*Jun 5 15:49:01.116: %Cisco-SDWAN-Router-FTMD-4-WARN-1000007: R0/0: FTMD: Connection to TTM came up. p_msgq 0x7f6a53835500 p_ftm 0x9296f0
*Jun 5 15:49:02.304: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 5 15:49:02.305: %CRYPTO-6-GDOI_ON_OFF: GSuite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 None ipbasek9
Configuration register is 0x2142
Router(config)#
*Jun 5 15:49:05.524: SDWAN INFO: application database sync to FPM: record-count 1426 error 76
*Jun 5 15:49:07.491: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#
*Jun 5 15:49:14.981: %NDBMAN-5-ACTIVE: R0/0: ndbmand: All data providers active.
*Jun 5 15:49:18.583: %DMI-5-ACTIVE: R0/0: dmiauthd: process is in steady state.
*Jun 5 15:49:32.983: %MODULE_STATE-6-ALL_MODULES_UP: All modules are now on-line.
*Jun 5 15:49:28.927: %DMI-5-INITIALIZED: R0/0: syncfd: process has initialized.
*Jun 5 15:49:36.518: %DMI-3-NETCONF_SSH_ERROR: R0/0: ncsshd_bp: NETCONF/SSH: error: Trustpoint does not have a cert
*Jun 5 15:49:41.228: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level debugging, xml disabled, filtering disabled, size (262144)
*Jun 5 15:49:41.462: SDWAN INFO: PNP start, status: success
Router(config)#
Router(config)#
*Jun 5 15:49:41.403: %DMI-5-CONFIG_I: R0/0: nesd: Configured from NETCONF/RESTCONF by nesd, transaction-id -1
*Jun 5 15:49:41.462: %DMI-5-ACTIVE: R0/0: nesd: process is in steady state.
Router(config)#
Router(config)#
Router(config)#
Router(config)#
Router(config)#con
Router(config)#confi
Router(config)#config-
Router(config)#config-register 0x2102
Router(config)#do sh ver
software.
ROM: IOS-XE ROMMON
Router uptime is 2 minutes
Uptime for this control processor is 4 minutes
export@cisco.com.
Configuration register is 0x2142 (will be 0x2102 at next reload)
Router(config)#username neteng
Router(config)#username neteng secre
Router(config)#username neteng secret cisco@123
Router(config)#ena
Router(config)#enable secre
Router(config)#enable secret cisco@123
Router(config)#ip ssh
Router(config)#ip ssh ver
Router(config)#ip ssh version 2
Router(config)#line
Router(config)#line vty
Router(config)#line vty 0 4
Router(config-line)#go
Router(config-line)#log
Router(config-line)#logi
Router(config-line)#login loc
Router(config-line)#login local
Router(config-line)#tra
Router(config-line)#transport inp
Router(config-line)#transport input ssh
Router(config-line)#^Z
Router#
Router#
Router#
Router#
Router#
*Jun 5 15:52:17.107: %SYS-5-CONFIG_I: Configured from console by console
Router#
Router#
Router#
Router#
Router#
Router#conf t
Router#
Router#conf
Router#configu
Router#configure ?
confirm Confirm replacement of running-config with a new config
file
memory Configure from NV memory
network Configure from a TFTP network host
overwrite-network Overwrite NV memory from TFTP network host
replace Replace the running-config with a new config file
revert Parameters for reverting the configuration
terminal Configure from the terminal
<cr> <cr>
Router#configure ter
Router#configure terminal ?
lock Lock the configuration mode
<cr> <cr>
Router#
Router#configure terminal lo
Router#configure terminal lock
Router#
Router#con
Router#confi
Router#config
27 Replies 27
Leo Laohoo
What, exactly, is the problem?
The router is booting in SD-WAN.  This means saving a config, in CLI, is not possible.
Thanks Leo,
So, how can I change it's mode for normal configuration. Please advise how can I change SD-WAN mode to normal mode.
razeev rohilla
it is booting now with this image: ISR Software (X86_64_LINUX_IOSD-UCMK9-M), Version 16.9.2, RELEASE SOFTWARE (fc1)
and earlier it is booting with image: ISR Software (X86_64_LINUX_IOSD-UNIVERSLAK9-M), Version 16.6.6, RELEASE SOFTWARE (fc1)
So, kindly advice how can i move back to ISR Software (X86_64_LINUX_IOSD-UNIVERSLAK9-M), Version 16.6.6
Please assist.
If the router is still in ROMMON, post the complete output to the command "set".
razeev rohilla
Hi Leo,
will check and reply. meanwhile can you check in logs, is IOS corrupt from flash ?
If the router can boot into SD-WAN profile, then it is guaranteed the flash is not corrupt.
razeev rohilla
but it shows:-
means original IOS image ISR Software (X86_64_LINUX_IOSD-UNIVERSLAK9-M), Version 16.6.6 was not in flash. that's why it is not booting. or image have in flash we have to select boot preference.
please suggest.
Because someone has misconfigured the boot variable statement.
First things first.  If the router is booting into ROMMON, provide the output to the command "set" so we can get the router to boot into "autonomous" (non-SDA).  Once we get that one fixed, then we can fix the boot variable statement.
razeev rohilla
i will get access of router with in 20-30 min. than i share "set" command output. please be available if you can. or suggest me how can i boot router in NON-SDA Mode.
The answer is in the "set" command.
razeev rohilla
ok, i will share set command output with you within a few minutes.
razeev rohilla
set command output:-
rommon 2 > set
PS1=rommon ! >
THRPUT=
BSI=0
RET_2_RCALTS=
RANDOM_NUM=1825638384
In ROMMON, enter the following command:
set DEVICE_MANAGED_MODE=autonomous
WARNING:  Above command is very case sensitive.
Reboot and see what happens.
If not, in IOS, enter the command:
controller-mode disable
can it is use with: set controller-mode disable
