Configure Fiber With ISR C1101-P
vpoon87
Hi all,
I'm having a problem setting up an ISR C1101-P to work with our fiber Internet provider. We have an ethernet handoff from the fiber provider. They provided us a /29 block of public IP addresses and also advised us what our WAN IP address should be. I plan to connect our firewall on Gig0/1/0 and number it with an available public IP. I have the default route pointing to the Internet provider's Serial IP address in the configuration but the devices on our public IP side do not route to the WAN side and to the Internet.
I've setup older models of the Cisco routers similarly but this is the first time I'm using an ISR model. What am I missing?
Here is the configuration and thanks in advance.
Victor
version 16.8
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname router1
boot-start-marker
boot-end-marker
no aaa new-model
subscriber templating
no license smart enable
diagnostic bootup level minimal
redundancy
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address 2.2.2.1 255.255.255.252
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Vlan1
ip address 1.1.1.1 255.255.255.248
ip default-gateway 2.2.2.2
no ip nat settings support mapping outside
ip forward-protocol nd
no ip http server
ip http secure-server
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Ok i understand in that case you can do like this
switchport access vlan 10
no shutdown
interface Vlan1
no ip address
interface Vlan10
ip address x.x.202.193 255.255.255.224
no shutdown
this should work.
BB
10 Replies 10
balaji.bandi
FW does the NAT config you may not see some config - that was configured automatically.
try below basic config see if that work before makes more complex config or your requirement :
ip nat outside
negotiation auto
interface Vlan1
ip nat inside
no ip default-gateway 2.2.2.2
access-list 1 permit 1.1.1.0 0.0.0.7
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 2.2.2.2
TESTINGs:
1. ping 2.2.2.2 is that working (hope 2.2.2.2 is the provider IP replace with real ip in config)
2. ping 8.8.8.8
3. configure PC with 1.1.1.X series IP address ( make sure you use google DNS 8.8.8.8) test and advise.
BB
Hi BB,
Thank you very much for the reply. However, it's still not routing between the interfaces. Here is what I have and can't still ping devices between each other over the router.
Victor
version 16.8
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
license udi pid C1101-4P sn FGL233215DK
redundancy
ip nat outside
negotiation auto
interface Vlan1
ip nat inside
ip http server
ip http authentication local
control-plane
line con 0
stopbits 1
line vty 0 4
password xxxxxxxxx
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
it's still not routing between the interfaces. I-  Like to know more, i was in the impression you have a Router connected to the (router interface configured and belong to VLAN 1) switch - and the device has (PC 1.1.1.X address)  - is this correct or please explain more to understand.
questions :
1. Are you able to ping from the router to 2.2.2.2?
2. are you able to ping from router 8.8.8.8 ?
is this 2.2.2.X address and 1.1.1.X is the real config of the device ? or changed or masked with original information?
BB
Hi BB,
I have the setup in a lab environment right now so I can't ping 8.8.8.8. I have pingable devices connected to both interfaces so I can test the configuration through end to end. The devices (PCs) have the IP addresses I have assigned from the ISP. On the LAN side, the IP address is a usable IP address within our LAN. The other PC on the WAN side has the serial IP of the ISP.
The addresses were changed to make the original configuration but the subnet masks are the original assigned by the ISP.
Victor
balaji.bandi
The other PC on the WAN side has the serial IP of the ISP.  - This means you are not really connected to ISP ? so how do you expect to ping to 8.8.8.8
i am afraid we can assist with the imagination of IP addresses here. Please do post correct information masking first 2 octets on the publci side IP and Local IP anyway RFC 1918 so no need to mask to understand the problem correctly.
Do you have any paper with you, please do draw a small diagram of how this connected, i do not see any config on the Router Lan side on the port (which one connected) other than VLAN 1 config?
what kind of more testing you did, what is not working, what is the end goal?
BB
I'm not able to connect the device to the Internet as I need to configure the device and ship it to a different location. That is why I have setup the device in a lab with PCs acting as the remote IP devices. I am trying to hook up things like this-
[Diagram Description automatically generated]
balaji.bandi
here is sample config on router  and FW need to configure to work.
ip address x.x.127.210 255.255.255.252
no shutdown
no shutdown
no interface Vlan1
no ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 x.x.127.209
Test  -
2. are you able to ping ISP IP x.x.127.209 ?
1. On the FW configure as mentioned Interface 0
x.x.202.194 255.255.255.224
2. you FW need to configure NAT
3. FW default route point t0 x.x.202.193
BB
Hi BB,
That is how I've had other Cisco routers configured before but on this device I am not able to directly put an IP address on Gig0/1/0 as it doesn't take the command. I'm not able to "no interface Vlan1" either as it says I cannot delete the default Vlan.
Victor
no shutdown
interface Vlan1
no ip address
interface Vlan10
no shutdown
this should work.
BB
Thanks for your help BB!
That worked!
Victor
