Cisco ASA 5508 - Dual ISP Setup with PBR or VLAN Tagging
Neorax
In the near future I will have a Cisco asa 5508.
Im a total begginer in this btw
I want to use a dual ISP Setup.
I have multiple Cisco Access points which I want to use. Now for the real question:
I want to have a main network in which every Device automatically gets put in (ISP 1)
Then I want to have selected Devices which can access Network over my ISP 2
Is PBR enough for completing this? Since I could route the different devices with static IP to my ISP 2 for example
or do I need to setup VLAN Tagging so that my devices can route with using the different VLAN Taggs?
Thanks in advance
balaji.bandi
yes PBR can be used here to achieve, are you looking failover if ISP 1 or 2 failover, then you need to Look for IP SLA and NAT clear.
here is good thread help you :
https://community.cisco.com/t5/routing/dual-isp-termination-on-asa-5508/m-p/3014812
https://community.cisco.com/t5/network-management/setting-up-asa-5506-x-with-dual-isp/m-p/4130876
https://integratingit.wordpress.com/2019/11/24/asa-dual-isp-using-ip-sla/
BB
11 Replies 11
balaji.bandi
BB
Thanks for the quick reply.
From my understanding failover means if one ISP goes down the other one takes over right?
I am building a normal Enduser Network (ISP1) and a private one (ISP2). Therefore there should be no failover whatsover. If there would be no solution like this then I'd use ISP 1 as failover when ISP 2 goes down.
You can have both the solution, failover or equally use both the links, and failover when required.
you may not be able to give 100% satisfaction service, but you have servce available.
what i mean was :
take example of the ISP Link 1 -10MB and ISP 2 Link 10MB
if you using each link 50% you can 100%  Service when it fail over either of link.
if both the link using 10MB full capacity, the Service may degrade, but you have service available.
Hope this make sense what you deploying scenario works.
BB
This wont work as the networks should never be connected. The private Network is only for secure devices and the other one is for everyone.
I still get the point you are trying to make tho!
Oh that make sense, i was in impression both ISP internet based.
then you have only  PBR to route respected outgoing interface.
BB
Neorax
Also is PBR possible by using mac-address for devices that do not have a static IP?
Just read that it is possible
where did you read that you can match on MAC addresses ? I am not sure you can...
There happens to be another thread on the forum where a user is trying to accomplish PBR to two different ISPs. The process was quite tricky, and a few things need to be kept in mind. In the configuration example below, you want three hosts to go out through the link to ISP2, and the rest through the link to ISP1 (the default). IP addressing is obviously arbitrary, you need to use whatever IP addresses you have configured:
interface GigabitEthernet1/1
ip address 192.168.10.1 255.255.255.0
nameif inside
security level 100
policy-route route-map ISP-RM
access-list HOST1 extended permit ip host 192.168.10.12 any
access-list HOST2 extended permit ip host 192.168.10.13 any
access-list HOST3 extended permit ip host 192.168.10.14 any
route-map ISP-RM permit 10
match ip address HOST1 HOST2 HOST3
set ip next-hop 2.2.2.2
interface GigabitEthernet1/2
description Link to ISP1
nameif outside1
security level 0
ip address 1.1.1.1 255.255.255.252
interface GigabitEthernet1/3
description Link to ISP2
nameif outside2
security level 0
ip address 2.2.2.1 255.255.255.252
nat (inside,outside1) 1 source dynamic any interface
nat (inside,outside2) 2 source dynamic any interface
route outside1 0.0.0.0 0.0.0.0 1.1.1.2 1
route outside2 0.0.0.0 0.0.0.0 2.2.2.2 10
Hello I read it while looking for a WLAN Access point. Not sure if its possible on Cisco devices tho ^^
Thanks for the Config - this may sound dumb but how would I insert my devices in the Hostlist?
Would I just need to configure the given IP from the 192.168.10.12 / 13 / 14 to my devices?
-- Obviously I would need to configure my own IP address for the rest --
Thanks in advance!
You add the ACL with the propose config, and add more IP same way given example to add more network hosts here .
BB
indeed, just replace the IP addresses marked in bold with your own, and add the access list names to the route map match clause:
