Configure L2TP On Router using Sub interface
alibahrian110
Hi There,
I have 2x2800 routers with NME-16ES-1G-P - 16-port 10/100 Cisco EtherSwitch Service Module installed in it.
I created L2tp tunnel using Physical interfaces on the routers. It works fine. laptops could ping each other.
Now I Want to create a L2TPtunnel from the router sub interface to another router physical interface.
Following config I applied. Tunnel comes up but the two laptops cant ping.
Following is the Config
Service Module-1
Int fa 1/0/1
     Desc laptop-1 having IP 172.16.0.1 255.255.0.0 is connected on this port.
     Sw acc vlan 1
Int gi 1/0/2
     Desc Internal Dot1q Trunk
     sw mode tr
     sw trun en dot1q
On Router-1
L2tp-class  l2tpclass11
pseudowire-class pseudoclass11
       encap l2tpv3
       internetworking ethernet
       protocol l2tpv3 l2tpclass11
       ip local interface loopback 0
Int loopback 0
    ip add 10.1.1.1 255.255.255.255
int gi 0/0
      Desc Directly connected to Router-2 on port gi 0/0
      ip add 10.0.0.1 255.0.0.0
Inter gi 2/0
       Desc Trunk to Switch Module
       ip add 192.168.0.1 255.255.255.0
Inter gi 2/0.1
xconnect 10.2.2.2 22 encap l2tpv3 pw-class pseudoclass11
Service Module-2
Int fa 1/0/1
      Desc laptop-2 having IP 172.16.0.2 255.255.0.0 is connected on this port.
     Sw acc vlan 1
Int gi 1/0/2
     sw mode tr
     sw trun en dot1q
On Router-2
       encap l2tpv3
Int loopback 0
    ip add 10.2.2.2 255.255.255.255
int gi 0/0
      Desc Directly connected to Router-1 on port gi 0/0
      ip add 10.0.0.2 255.0.0.0
Inter gi 2/0
Inter gi 2/0.1
xconnect 10.1.1.1 22 encap l2tpv3 pw-class pseudoclass11
OSPF is running so all the routng is in place. Router 1 can ping router 2 loopback and other IP address.
L2TP tunnel comes up straight away but Laptop-1 cant ping laptop2 and vice versa.
Any sggestion whats wrong in the config.
5 Replies 5
Julio E. Moisa
If you are going to use L2TP with Sub-interfaces, everything needs to be configured with sub-interfaces including the CE routers, otherwise the L2VPN will be up but not traffic transit through, You can verify the following example:
PE01
pseudowire-class L2VPN
encapsulation l2tpv3
ip local interface Loopback0
interface GigabitEthernet0/0
no ip address
negotiation auto
no keepalive
interface GigabitEthernet0/0.100
encapsulation dot1Q 100
xconnect 2.2.2.2 100 encapsulation l2tpv3 pw-class L2VPN
PE02
no ip address
negotiation auto
xconnect 1.1.1.1 100 encapsulation l2tpv3 pw-class L2VPN
CLIENT ROUTER01
interface G0/0
no ip address
interface G0/0.100
ip address 192.168.100.1 255.255.255.0
CLIENT ROUTER02
interface G0/0
no ip address
interface G0/0.100
ip address 192.168.100.2 255.255.255.0
If you are using Trunk on the client routers remember to allow the VLAN associated to the L2VPN.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio.
thanks for the suggestion however it didn’t work. I changed my config to adopt ur suggestion that all the connectivity should be based on sub interfaces.
So so I changed the interfaces on my both the router to subinterface i.e. changed the following for router 1
int gi0/0
no ip add
int gi0/0.1
encap dot1q 1
! For router 1
ip address 10.0.0.1 255.0.0.0
for router 2
int gi0/0
no ip add
int gi0/0.1
encap dot1q 1
! For router 1
ip address 10.0.0.2 255.0.0.0
rest of the config were the same. But no luck. I made sure that I was using only vlan 1 through the config n sub interface.
Can u suggest what is wrong now
thanks is advance.
is possible to share the config of the all devices involved on this L2VPN?
Thank you in advance.
HI Julio,
I have Two routers directly connected with each other using port gi0/0.
Both routers have 16 port switch module connected within the router chassis.
Diagram of this topology is attached in my first post. Please have a look at it as well. That diagram will tell you the topology I m using and
as requested, following is the config on two routers.
Switch Service Module-1
Int fa 1/0/1
     Sw acc vlan 1
Int gi 1/0/2
     sw mode tr
     sw trun en dot1q
On Router-1
       encap l2tpv3
Int loopback 0
int gi 0/0
      No ip address
Int gi0/0.1
      Encap dot1q 1
Inter gi 2/0
Inter gi 2/0.1
Switch Service Module-2
Int fa 1/0/1
     Sw acc vlan 1
Int gi 1/0/2
     sw mode tr
     sw trun en dot1q
On Router-2
       encap l2tpv3
Int loopback 0
int gi 0/0
      No IP address
Int gi0/0.1
      Encap dot1q 1
Inter gi 2/0
Inter gi 2/0.1
Thanks in advance.
Hi Julio.
Did u get a chance to look at the topology n the config?
