How to configure Policy NAT on ASA
yang yang
HI all
    I have a nat problem on ASA. the structure is simple. nat inside source device to outside interface IP ( nat (inside, outside) source dynamic obj_192.166.168.9 interface) the reason use dynamic nat is because their is other devices need to access the internet as well. but I do know how to nat the destination IP when traffic starts from outside. please check the topology on attach. I have tried:
( nat (outside,outside) source static any any dest obj_30.30.30.10 obj_192.166.168.9 server dest_port_9443 dest_port_21
nat (outside,outside) source sta any obj_30.30.30.10 dest obj_30.30.30.10 obj_192.166.168.9 server dest_port_9443 dest_port_21
nat (outside,inside) source sta any obj_30.30.30.10 dest obj_30.30.30.10 obj_192.166.168.9 server dest_port_9443 dest_port_21
nat (outside,inside) source static any any dest obj_30.30.30.10 obj_192.166.168.9 server dest_port_9443 dest_port_21)
they all are not working. I know this requires policy nat but I have some trouble to apply policy on ASA 9.4. can anyone help on this?
I am not clear on what you are asking: 192.166.168.9 is your inside address, and 30.30.30.10 your outside address ? Try the below:
ASA(config)# object network FTP_NAT
ASA(config-network-object)# host 192.166.168.9
ASA(config-network-object)# nat (inside,outside) static 30.30.30.10 service tcp ftp ftp
Hi Georg
  Thanks for your reply. previously I was thinking use dynamic nat from inside to outside(since another internal server is using that public IP address). Then apply another static or dynamic nat from outside to inside. but looks like when the user from outside to inside sending the package the traffic will catch by the first nat and will not fall down to the second nat. that is why I want to do two-way policy nat. this makes thing complicated and hard to solve even hit a limitation of the ASA interface cannot be reached by its own other connected interface subnet device.
   This morning when I wake up I have clear my idea. and you are right. that is the way. just do the static nat for a specific port from inside to outside will help in this situation. thank you.
all the best
yangyang
