Configure Multi Link PPP (Urgent Help Required)
guruprasadr
Level 7
Level 7
Hello All,
R1<----------->R2
Currently i have a E1 circuit between R1 and R2 Routers.
I am purchasing a new E1 circuit for Load Sharing with High availaibility.
I wish to Bundle the both the E1 Circuits as Single Virtual Link.
Please help me with the Sample Configuration of "Multi Link PPP"
Note: Both the E1 Circuits belong to two different Service Providers.
Thanks in Advance for Help
Best Regards,
Guru Prasad R
Hieu Cao
Level 4
Level 4
Take a look at the link below for PPP sample and explanation.
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
hth,
hieu
jerry.mcrae
interface Multilink80
bandwidth 3000000
ip address x.x.x.x 255.255.255.252
no ip mroute-cache
no cdp enable
ppp multilink
ppp multilink fragment disable
ppp multilink group 80
interface Serial0/0
description Qwest Internet
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
no ip mroute-cache
no fair-queue
no cdp enable
ppp multilink
interface Serial0/1
no ip address
no ip redirects
no ip unreachables
encapsulation ppp
no ip mroute-cache
no fair-queue
no cdp enable
ppp multilink
As per my knowledge the links which are bundeled together for MLPPP should be run between the same two routers.
so MLPP could not be used for links terminating on two different ISPs.
