General failure
tareqrebhi
dear,
General failure: Why this happenes and from where this error comes from?
Reply from 87.248.113.14: bytes=32 time=102ms TTL=48
General failure.
Reply from 87.248.113.14: bytes=32 time=103ms TTL=48
Reply from 87.248.113.14: bytes=32 time=105ms TTL=48
Reply from 87.248.113.14: bytes=32 time=104ms TTL=48
PING: transmit failed, error code 1232.
Reply from 87.248.113.14: bytes=32 time=110ms TTL=48
Reply from 87.248.113.14: bytes=32 time=111ms TTL=48
Reply from 87.248.113.14: bytes=32 time=109ms TTL=48
Reply from 87.248.113.14: bytes=32 time=124ms TTL=48
Reply from 87.248.113.14: bytes=32 time=126ms TTL=48
Reply from 87.248.113.14: bytes=32 time=121ms TTL=48
thank you.
Edison Ortiz
These are windows generic error codes.
For instance error code 1232 means "ERROR_HOST_UNREACHABLE 1232"
Were you pinging from your wireless connection ? If so, you may be dropping.
