Configure Site-to-Site VPN with dynamic IP on one side!
ittechk4u1
Level 4
Level 4
Hello Experts,
I want to configure  a IPSec tunnel with dynamic IP on remote site.
HQ (HUB)----------Remote Location
Here is my layout:
Info: HUB is using static IP routing for public IP routes, so its really hard to route a unknow IP!!! (Biggest issue) and i have a default router to our LAN from HQ router.
Thanks in advance.
10 Replies 10
have a look at the configuration example below:
CONFIGURING CISCO SITE TO SITE IPSEC VPN WITH DYNAMIC IP ENDPOINT CISCO ROUTERS
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/936-cisco-router-vpn-dynamic-endpoint.html
thanks for quick answer.
But my main issue is routing on HQ router!!
I do i route the dynamic ip from HQ routers as i do not have specific IP!!!
What is your meaning with routing with WAN IP address? You can implement a default route also from the ISP 2.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Sorry for typo.
I am routing WAN IP address for all 40 location statically (next hop is ISP and ISP2).
There is one default route available on HQ router and that is towards LAN: 0/0 10.18.2.254
all you need is a default route pointing to the outgoing interface on both the remote site and the HQ site...
ip route 0.0.0.0 0.0.0.0 interface X
Thanks again.
Problem is I already have a default route on HQ router towards LAN.
ip route 0.0.0.0 0.0.0.0 10.18.2.254
is that default route actually needed ? Typically, the LAN would be on a directly connected interface...
I think we need it.
Please have a look on the topology:
Deepak Kumar
The LAN to Remote site route will be done using the Tunnel interface IP address neither a public IP address and tunnel mode will be point-to-multipoint.
HQ Configuration will be like for Dynamic Remote (Spoke) IP address as:
interface Tunnel0
description mGRE - DMVPN Tunnel
ip address 172.16.0.1 255.255.255.0
no ip redirects
ip nhrp authentication firewall
ip nhrp map multicast dynamic
ip nhrp network-id 1
tunnel source 1.1.1.1 <Interface WAN Interface IP>
tunnel mode gre multipoint
Spoke Tunnel configuration as:
interface Tunnel0
 description R2 mGRE - DMVPN Tunnel
 ip address 172.16.0.2 255.255.255.0
 no ip redirects
 ip nhrp map 172.16.0.1 1.1.1.1
 ip nhrp map multicast 1.1.1.1
 ip nhrp nhs 172.16.0.1
 tunnel source FastEthernet0/1  <WAN Interface which is having dynamic IP address>
You can implement Dynamic routing or Static route as per your environment and destination host will be a tunnel interface.
Deepak Kumar,
Agree with you.
here are my config:
Remote:
Int gig0/0/2
desc *** Cradelpoint Router ***
ip address DHCP --> 37.85.167.30
ip mtu 1300
ip access-group internet in
ip tcp adjust-mss 1260
negotiation auto
no shut
int Tunnel 599
ip address 10.13.97.99 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication CRALTE
ip nhrp map 10.13.97.4 195.243.205.120
ip nhrp map multicast 195.243.205.120
ip nhrp network-id 99
ip nhrp holdtime 300
ip nhrp nhs 10.13.97.4
ip tcp adjust-mss 1360
tunnel source GigabitEthernet0/0/2
tunnel key 99
ip route 195.243.205.120 255.255.255.255 gig0/0/2 DHCP
HQ:
interface Tunnel599
ip address 10.13.97.4 255.255.255.0
no ip redirects
tunnel source 195.243.205.120
tunnel key 99
ip route <?> 255.255.255.255 195.243.205.99 name LTE_BKP_99
my issue is routing on HQ router! (I am using static IP routing for all other 40 locations)
