Configure T1 and passthrough IP?
jmhunter
Greetings,
I have a T1 handed off to me from my local ISP.  I have a Cisco 2620XM w/ 12.3(1a) installed.  Normally, at my other locations, I would have the T1 hit an ISP provided device and hand off to me as an Ethernet, but this was legacy before my time when it was ordered.
In short, I want to pass through this circuit to the firewall we use (Watchguard) via ethernet.  I've configured the router, and the T1 is up.  Not exactly sure what to do on the ethernet side, I did configure a network (took a private block, 192.168.0.x) but is this the best (or only) way to do this?  Here is my config:
Current configuration : 1752 bytes
version 12.3
hostname Warehouse-Cisco
boot system flash c2600-is-mz.123-1a.bin
logging buffered 4096 debugging
enable secret 5 $A-BunchOfRandomStuff
enable password 15 NotTheRealPassword
clock timezone CST -6
clock summer-time CDT recurring
ip subnet-zero
no ip routing
no ip domain lookup
ip domain name warehouse.MyDomain.com
ip name-server 4.2.2.2
ip name-server 4.1.1.1
no voice hpi capture buffer
no voice hpi capture destination
buffers verybig permanent 0
interface FastEthernet0/0
description Ethernet Side
ip address 192.168.0.1 255.255.255.0
no ip route-cache
speed auto
half-duplex
interface Serial0/0
description MYCiruitInfo ABunchOfNumberAndLettersHere
ip address 22.33.44.70 255.255.255.252
encapsulation ppp
no ip route-cache
fair-queue
service-module t1 timeslots 1-24
interface Serial0/1
description Not in Use
mtu 2104
no ip address
no ip route-cache
shutdown
clockrate 56000
ip default-gateway 22.33.44.69
ip http server
ip classless
no logging trap
Obviously my relavant information I changed to protect the innocent ;)
Thanks!
James
6 Replies 6
paolo bevilacqua
Ask you ISP what is your LAN address assigned and configure it on LAN interface. No NAT is needed.
Note: you will need to re-enable 'ip cache'
Thanks a lot!
I did have the LAN addresses (with 255.255.255.248 mask), I have configured the ethernet side with that.  I will configure the other end to an address within that above mentioned range.  You mentioned turning on IP route cache.  I did that for the FastEthernet but do I need to enable it for the Serial side?
also, I have IP routing turned off, just using a default gateway.  Should that be sufficient?
Thanks again,
James
No, being this a router, you need to have ip routing - the default. Then configure a default route.
And have (the default) of ip route-cache enabled everywhere.
Ok, so I enabled:
removed default-gateway
IP routing
IP route 0.0.0.0 0.0.0.0 11.22.33.44 (the distant endpoint of the T1).
Not pingable, but may not be a configuration issue.  Need to open ticket with Carrier.  Will update tomorrow.
THanks for all the help!
James
Check "show interface se0/0" to begin with.
Thank you for the nice rating and good luck!
The show Interface command gives me the following:
Serial0/0 is up, line protocol is up
  Hardware is PQUICC with Fractional T1 CSU/DSU
  Description: XO: 14/HCRT/242639..SW Loop: 03.HCRU.008646..ALPH
  Internet address is 64.46.167.70/30
  MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
  Encapsulation PPP, LCP Open
  Open: CDPCP, IPCP, loopback not set
  Last input 00:00:50, output 00:00:02, output hang never
  Last clearing of "show interface" counters 1d17h
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/2/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
     34766 packets input, 2233917 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     35408 packets output, 2261304 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     1 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
The circuit is indeed up, pingable from a remote location, so I know the circuit is good.  Still waiting on carrier information.
James
