configure vpn from gateway to gateway in cisco isr 1100 without buying the securityk9 license
unidadso
Good morning is how to configure VPN from gateway to gateway in Cisco ISR 1100 without buying the securityk9 license
5 Replies 5
the router comes with IP Base by default. You need to buy the Security (SEC) or IP Security (IPSEC) license for any sort of VPN. I don't see a way around that.
the vpn configuration was configured but when the securityk9 license expired the connections were lost with the other routers
balaji.bandi
if you do not have budget to buy license (you can try use any raspberry pi with VPN Server site to site both the site). - personal view to easy to fix your issue.
BB
What you recommend is that you configure the raspberry pi card?
here is good for reference :
https://www.raspberrypi.org/forums/viewtopic.php?t=223702
BB
