10-26-2021 01:02 AM
Hello
Someone kindly assist me.
I need to cofigure a VPN in Cisco 4300 such that workers can be able to access office network while at home
Kind Regards
10-26-2021 02:15 AM
Not sure what client you like to use, you want to use native windows client or Cisco Any connect ?
provided below both for reference :
https://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/809-cisco-router-vpn-client.html
https://www.youtube.com/watch?v=JL8lh0hq-F4
10-26-2021 03:59 AM
Easy VPN is probably the simplest solution. Post the running configuration of your 43xx router so we can fill in the bits and pieces...
10-26-2021 10:07 PM - edited 10-27-2021 02:44 AM
Hello
See attached configuration regards remote vpn access for cisco vpn cleints.
10-27-2021 12:31 AM
in addition to the other posts, here is a sample config for a 4331 configured as Easy VPN server:
version 16.8
service password-encryption
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname 4331
boot-start-marker
boot system flash bootflash:isr4300-universalk9.16.08.05.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
logging console emergencies
enable secret 5
transport-map type persistent ssh sshhandler
time-out 30
rsa keypair-name sshkeys
transport interface GigabitEthernet0
connection wait allow interruptible
transport-map type persistent telnet telnethandler
aaa new-model
aaa authentication login default local
aaa authentication login USERS-AUTHEN local
aaa authorization exec default local
aaa authorization network GROUP-AUTHOR local
aaa session-id common
no process cpu autoprofile hog
clock timezone GMT 1 0
ip nbar http-services
ip domain name yourdomain.com
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
subscriber templating
crypto pki trustpoint TP-self-signed-1843133077
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1843133077
revocation-check none
rsakeypair TP-self-signed-1843133077
crypto pki certificate chain TP-self-signed-1843133077
certificate self-signed 01
quit
ivr prompt buffers 2
license udi pid ISR4331/K9 sn
license accept end user agreement
license boot level appxk9
license boot level uck9
license boot level securityk9
diagnostic bootup level minimal
username admin privilege 15
username guest privilege 15
username operator password 7
redundancy
mode none
vlan internal allocation policy ascending
no cdp run
crypto isakmp policy 10
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group VPN-GROUP
key KEY1
dns 192.168.1.1
pool EZVPN-POOL
acl 101
crypto isakmp profile VPN-CLIENT
match identity group VPN-GROUP
client authentication list USERS-AUTHEN
isakmp authorization list GROUP-AUTHOR
client configuration address respond
crypto ipsec transform-set TS-3DES-MD5 esp-3des esp-md5-hmac
mode tunnel
crypto dynamic-map DYNMAP 10
set transform-set TS-3DES-MD5
set isakmp-profile VPN-CLIENT
reverse-route
crypto map DMAP 1 ipsec-isakmp dynamic DYNMAP
interface GigabitEthernet0/0/0
description WAN
ip address dhcp
ip mtu 1452
ip nat outside
ip nbar protocol-discovery
ip tcp adjust-mss 1412
negotiation auto
pppoe enable group global
pppoe-client dial-pool-number 1
spanning-tree portfast trunk
interface GigabitEthernet0/0/1
description LAN
ip nat inside
negotiation auto
spanning-tree portfast disable
interface GigabitEthernet0/0/2
shutdown
interface GigabitEthernet0/1/0
shutdown
interface GigabitEthernet0/1/1
shutdown
interface GigabitEthernet0/1/2
switchport mode access
shutdown
interface GigabitEthernet0/1/3
shutdown
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
no cdp enable
interface Vlan1
no ip address
shutdown
interface Dialer1
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp mtu adaptive
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username
ppp ipcp dns request
crypto map DMAP
ip local pool EZVPN-POOL 192.168.2.10 192.168.2.250
ip nat inside source route-map ISP_NAT_RM interface Dialer1 overload
ip forward-protocol nd
ip ftp username 1
ip ftp password 7
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 Dialer1
ip ssh version 2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
dialer-list 1 protocol ip permit
route-map ISP_NAT_RM permit 10
match ip address 1
match interface Dialer1
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
end
