Configuring a 3945 Router's Gigabit Ports for internet connectivity.
RBM01991
Team, I would like to use gi0/2 as a way to get my internet in from my ISP. The ONT has an Ethernet port on it, that is currently connected to an HWIC-1FE card which provides me with 100 mbps. Since I'm going to upgrade to 500 mbps, and possibly Gigabit, I need to have a compatible port on this router. Can anyone provide me with some configuration steps on how to do it?
Here's the running config on my router at the moment. Thanks in advance!
Building configuration...
Current configuration : 2671 bytes
! Last configuration change at 10:43:44 EST Thu Jan 2 2020
version 15.7
hostname HomeRouter-001
boot-start-marker
boot system flash:c3900-universalk9-mz.SPA.157-3.M5.bin
boot-end-marker
enable secret 5 $1$d.au$f/puBghk0fn9ztVqTehNn.
no aaa new-model
clock timezone EST -5 0
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool internal
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 8.8.8.8 8.8.4.4
 netbios-name-server 192.168.1.1
 lease infinite
ip dhcp pool internal2
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
 netbios-name-server 192.168.2.1
 lease infinite
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip cef
no ipv6 cef
voice-card 0
vxml logging-tag
license udi pid C3900-SPE150/K9 sn FOC15505HWS
license accept end user agreement
license boot module c3900 technology-package datak9
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/2
 ip address dhcp
 ip access-group ISP in
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/0/0
 description INTERNET
 ip address dhcp
 ip access-group MY-WAN in
 ip nat outside
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 1 interface FastEthernet0/0/0 overload
ipv6 ioam timestamp
nls resp-timeout 1
cpd cr-id 1
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
Hello
If you want to swap the port around well that can be done but you need to change any routing (dynamic/static) any nat configuration pointing to the old interface to the new interface, plus keep in mind your going from a 100mb fastethernet to gigabitethernet so the otherside of the connection needs to be able to support gigabit otherwise you will have to hardcode the gigabit interface down to a lower speed
Example
conf t
default interface gig0/2
default inerface fa0/0/0
no ip nat inside source list 1 interface FastEthernet0/0/0 overload
no ip route 0.0.0.0 0.0.0.0 FastEthernet0/0/0 dhcp
ip address dhcp
ip nat outside
ip address dhcp
ip nat outside
ip nat inside source list 1 interface GigabitEthernet0/2 overload
Kind Regards
Paul
16 Replies 16
Hello
You could possibly procure a wan card for one for the EHWIC slots and use that, or if the router has any spare sfp slots use a 1gb copper sfp?
Kind Regards
Paul
I have an EHWIC-4SG card installed in the router, but it doesn't show up in my interfaces and I can't figure out why. I was going to use that, until someone told me that I could use the regular ports on the router to do what I'm trying to do.
Hello
Is that card compatible for that router?
Have you tried another HWIC slot?
Have you rebooted the router after inserting the card?
You can if you have any spare?
sh inventory
sh version
sh ip int brief
Kind Regards
Paul
I've done all 3 of those and the card still doesn't show up, however if I do sh inventory or sh diag, it comes up there.
If you have done all the steps suggest, this module is not hot-swappable as per my experience. and you able to see the show inventory.
then try other suggestions as per the below and let us know how it goes?
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html#71280
You still have an issue, please show below information :
show inventory
show interfaces
show license
BB
I'll try those in the morning, thank you.
I also do have a Gigabit port on the router itself free, I have Gigabit 0/0 connected to my switch, Gigabit 0/1 connected to my server and Gigabit 0/2 is free and its the one I intend on using for this purpose.
if the ports are free you can use them too. (i do not see any issue here)
BB
Ok, so would I configure gi0/2 in this instance?
you have come configuration already as below :
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
make appropriate changes and test it, make sure you change the routing from your FastEther to the new port and adjust the config accordingly.
BB
Ok, so I did that, but what do you mean change the routing from FE to the new port?
since OLD connection connected to FE port, now you moved to Gig Port, so make necessary changes if required to go to internet using new port i mean.
BB
Hello
Example
conf t
ip address dhcp
ip nat outside
ip address dhcp
ip nat outside
Kind Regards
Paul
Unfortunatelly that didn't work, as soon as I copied and pasted that configuration and switched the cable over from FE to GI0/2, I lost complete internet connectivity.
