Configuring a 3945E for Internet Access
RBM01991
Good evening team,
I am in the middle of configuring my Cisco ISR G2 3945e as my home router. I'm replacing my standard Frontier router with the Cisco router.
My problem is that now as I've configured everything, my main computer in my bedroom is the only one that has internet access, and the one thing I've noticed is that in its default configuration, it gets the default gateway just fine. However my other devices do not receive my default gateway, even after attempting to reset their connections. All of my other wired devices are connected via a Cisco 4948 Switch. I can post the running config of that if it helps.
Here is the running config of the Router. Please let me know if you see anything off.
Building configuration...
Current configuration : 1937 bytes
! Last configuration change at 12:24:22 EST Mon Dec 16 2019
! NVRAM config last updated at 12:24:30 EST Mon Dec 16 2019
version 15.1
hostname
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.30
ip dhcp pool internal
network 192.168.1.0 255.255.255.0
default-router 47.198.202.82
dns-server 8.8.8.8 8.8.4.4
netbios-name-server 192.168.1.1
lease infinite
no ip domain lookup
voice-card 0
license udi pid C3900-SPE150/K9 sn FOC15505HWS
license accept end user agreement
license boot module c3900 technology-package datak9
redundancy
interface GigabitEthernet0/0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet0/2
ip address dhcp
duplex auto
speed auto
interface FastEthernet0/0/0
description INTERNET
ip address dhcp
ip access-group MY-WAN in
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0/0 overload
logging esm config
access-list 1 permit 192.168.1.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
password
logging synchronous
line aux 0
password
login
line vty 0 4
password
login
transport input all
scheduler allocate 20000 1000
end
the default router configured in your DHCP pool looks odd:
lease infinite
Change that to:
default-router 192.168.1.1
lease infinite
balaji.bandi
Like to see your Switch configuration and what port it is connected to your router also will be helpful email.
what IP address your computer got and it was working, how different this device connection compare to not working one.
what is this IP address in your DHCP config? - default-router 47.198.202.82
BB
lease infinite
Change that to:
lease infinite
