Router 892FSP subinterfaces
npranger
Hello,  I attempting to configure a 892FSP for a router on a stick interface situation.  I want a network with staff wifi Vlan, guest wifi vlan, management vlan, and a native vlan.  I think i understand setting up the trunks with the 1 switch and multiple APs, but I can not understand the correct syntax CLI for this router to create the vlans and subinterface.  I was tasked to help this church out.  Any assistance would be appreciated. Thanks
4 Accepted Solutions
npranger
I cannot successfully get the subinterface configured. I use the following syntax;
Config# Interface g1
Config-if# no shutdown
Config-if# exit
Config# interface g1.10
This command fails.  Any help would be appreciated.
Can you post show version output to check the feature available :
or you can try below
interface GigabitEthernet0/2
 no ip address
 duplex auto
 speed auto
 port-tagging
  encapsulation dot1q 10
  set cos 6
  exit
end
interface GigabitEthernet0/2.1101
encapsulation dot1Q 100
ip address 132.1.101.4 255.255.255.0
interface GigabitEthernet0/2.1102
ip address 132.1.102.4 255.255.255.0
https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_010110.html?bookSearch=true
BB
Joseph W. Doherty
Cannot say for sure, without getting much deeper into the specifics of the 892FSP ISR, but some possibilities that can arise include:  subinterfaces not supported on that particular (kind) of gig interface (especially in the LAN switch port bank), or feature set doesn't support (that particular 800 ISR is a "High Performance Security" variant), or your particular IOS version (which is?) doesn't support subinterfaces (interestingly, looking at release notes for a couple of 15.x trains, noticed some known bugs concerning using subinterfaces - bugs bad, but at least mention of subinterfaces implies feature exists), etc.
Good!  Glad to read you're having more success with a 2911 (which, I recall, has more capacity than a 89x, too).
9 Replies 9
balaji.bandi
check the below config to help you :
https://www.cisco.com/c/en/us/support/docs/lan-switching/inter-vlan-routing/14976-50.html
BB
Hello, thank you for your input. I will study the document.
npranger
Config-if# exit
 no ip address
 duplex auto
 speed auto
 port-tagging
  set cos 6
  exit
end
BB
Joseph W. Doherty
 Thanks for your advice.  I appreciated your effort.  I ditched the 892 router.  I found a cheap 2911 router. Configuration is going much easier now.
Sure what ever works for you is easy ..if you can buy another router that works for you.
BB
Joseph W. Doherty
". . . I can not understand the correct syntax CLI for this router to create the vlans and subinterfaces."
(For subinterfaces, only found mention when using with ATM [DSL].)
