Configuring Admin Distance in Static Route
rivanfrank
Hi Everyone,
I need help to clarify this on my mind. At first I put static routes on both routers and put admin distance of 151.
router1(config)#ip route 192.168.16.0 255.255.255.240 10.0.0.2 151
router2(config)#ip route 192.168.8.0 255.255.255.248 10.0.0.1 151
Second, I put RIP on both routers (for fun)
router1(config)#router rip
router1(config-router)#network 192.168.8.0
router1(config-router)#network 10.0.0.0
router2(config)#router rip
router2(config)#network 192.168.16.0
router2(config)#network  10.0.0.0
show ip route
router1#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/14 is subnetted, 1 subnets
C       10.0.0.0 is directly connected, Serial0/0/0
     192.168.8.0/29 is subnetted, 1 subnets
C       192.168.8.0 is directly connected, FastEthernet0/0
S    192.168.16.0/20 [151/0] via 10.0.0.2
R    192.168.16.0/24 [120/1] via 10.0.0.2, 00:00:26, Serial0/0/0
I understand that RIP will work but my concern is when i type sh ip route, static routes are still showing, is this normal? I thought it will disappear and only RIP will show. And by the way routes still works it's just the static route is still showing that bothers me.
Thanks.
3 Accepted Solutions
The route you configured has a different subnet-mask then the route you received. And the config-line above has again a different mask than the others.
If your configured static route had the same subnet-mask as the learned RIP-route, you would only see the RIP-route as long as the RIP-route is available.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
mahmoodmkl
Level 7
Level 7
the subnet masks is differnt for static routes n rip routes so both of thm are installed in the routing table if the masks were same thn only rip routes could be there.
let us know the issue u r facing
you should do no auto-summary under the RIP process on both routers then the /24 RIP routes will become /28 and  /29
and as you have static routes for these same prefixes but with a higher AD , the RIP routes will get installed in the routing tables replacing the  static routes.
Regards.
Alain
6 Replies 6
Thanks karsten.iwen.
I misconfigured the static route but it's now fixed but can you tell if there is something wrong here?
router1
     192.168.16.0/24 is variably subnetted, 2 subnets, 2 masks
R       192.168.16.0/24 [120/1] via 10.0.0.2, 00:00:05, Serial0/0/0
S       192.168.16.0/28 [151/0] via 10.0.0.2
router2
     192.168.8.0/24 is variably subnetted, 2 subnets, 2 masks
R       192.168.8.0/24 [120/1] via 10.0.0.1, 00:00:00, Serial0/0/0
S       192.168.8.0/29 [151/0] via 10.0.0.1
     192.168.16.0/28 is subnetted, 1 subnets
C       192.168.16.0 is directly connected, FastEthernet0/0
Thanks.
Regards.
Alain
Thank You! I remember that rip is classful. Big Help! and it now works!
mahmoodmkl
Level 7
Level 7
