COnfiguring an ASA5506X for NAT
Paul Morris
I am not sure if this is the correct forum but I need to configure a ASA 5506X to do NAT routing. I think I have successfully configured the internal and external interfaces but so far it is still not working.
Any assistance would be appreciated.
Paul,
You didn't provide dns address. I already used public one and you can change it anyway.
* for your outside interface use..
      interface gigabitethernet1/1
      nameif outside
      security-level 0
      ip address dhcp setroute
      no shutdown
*for your inside interface use...
    interface gigabitethernet1/2
    nameif inside
    security-level 100
    ip address 10.0.0.1 255.255.255.0
    no shutdown
*to enable DHCP service on your internal network use...
  dhcpd dns 4.2.2.2 4.2.2.3
  dhcpd lease 3000
  dhcpd ping_timeout 30
 dhcpd address 10.0.0.100-10.0.0.250 inside
 dhcpd enable inside
* to enable Nat process outside to/from inside use...
   global (outside) 1 interface
   nat (inside) 1 10.0.0.0 255.255.255.0
   access-group 101 in interface outside
* to enable telnet on inside interface use...
   telnet 10.0.0.0 255.255.255.0 inside
   telnet timeout 10
* to save the configurations use ( write ) command.
Also, dont forget to enable password for the device
Please rate helpful posts
42 Replies 42
rizwanr74
Level 7
Level 7
What kind of nat you want to do?
Explain nature of your nat you needed?
Based upon a previous recommended configuration I need to use the ASA to connect the internal network with the external (WAN) which are on two different IP addresses
You would need a static nat.
ASA 8.2 and below.
access-list outside-in permit tcp any host 23.23.23.23 443
access-group outside-in in interface outside
static (inside,outside) 23.23.23.23 10.50.50.50 netmask 255.255.255.255
For version 8.3 and above.
object network my-internal-srv
 host 10.50.50.50
 nat (inside,outside) static 23.23.23.23
access-list outside-in extended permit tcp object-group my-internal-srv any eq 443
You may change IP address, according to your enviorment.
thanks
I am new to Cisco CLI. Is this via the CLI or ASDM. I do not have the ASDM.
If via the CLI do I use the Interface 1/1 for outside?
It is CLI configuration.  You have to change port number, private ip address and public ip address according to your enviorment.
Use interface's names what you have defined on the interfaces.
Can you give me the complete list of commands to ensure I get it right?
What provided is the complete list of commands you needed to complete static-nat.
Configuration commands varies based software version of ASA, as mentioned above.
Will try those shortly and let you know.
Thank you very much.
Is 10.50.50.50 the IP address for your firewall or internal gateway?
"Is 10.50.50.50 the IP address for your firewall or internal gateway?"
This is just an example to setup static-nat for an internal address, so that someone coming via the Internet will be able to access your Internal service running on port 443 on server address 10.50.50.50.
Are you trying to access the Internet from inside of your network?
The primary aim is to access the internet from the internal network.
The external is set to 192.168.x.x and the internal is 10.x.x.x
You cannot access the Internet with private address ranges.
You need to dynamic-nat your private addresses to public address on outside interface of your ASA, which is facing the Internet circuit.
What version of your ASA's software?
Below table shows, private address range.
RFC1918 nameIP address rangenumber of addresseslargest CIDR block (subnet mask)host id sizemask bitsclassful description[Note 1]
24-bit block10.0.0.0 - 10.255.255.25516,777,21610.0.0.0/8 (255.0.0.0)24 bits8 bitssingle class A network
20-bit block172.16.0.0 - 172.31.255.2551,048,576172.16.0.0/12 (255.240.0.0)20 bits12 bits16 contiguous class B networks
16-bit block192.168.0.0 - 92.168.255.25565,536192.168.0.0/16 (255.255.0.0)16 bits16 bits256 contiguous class C networks
 I am not sure of the version of the software.
The reason the External ip is a 192 is that the ISP has a DIA and are using a device which does its own routing. We can't and don't access that device but it gives a 192.168.0.x scheme.
On console access, issue this command "show version"
