11-10-2014
09:47 AM
- last edited on
03-25-2019
03:42 PM
by
ciscomoderator
Can someone tell me the part number for a PoE power supply for the router Cisco 891FW.
Note that it doesn't look like the regular 891 power supplies but it looks like a plastic rectangle with 4 pins.
Thank you.
11-10-2014 01:44 PM
11-10-2014 01:48 PM
Hi Leo,
The router I'm trying to power has only one power connector (the rectangular one with 4 pins) so I guess I need the 125 watt power supply??
Regards.
11-10-2014 02:02 PM
Ok, here's how it goes ...
If you buy the router and you've also purchased the PoE daughter card, the router will come with the PoE daughter card pre-installed. You'll also get the 125-watt power supply.
However, if you didn't get the PoE daughter card, the router will be delivered with a smaller 80-watt power supply.
Now, let's say you ordered a PoE daughter card. When you do this, you'll be given the option to get the 125-watt power supply. You now swap out the 80-watt power supply with a 125-watt power supply.
11-10-2014 02:15 PM
11-10-2014 02:31 PM
so I guess it already has the daughter card installed
You don't make an assumption like that.
Post the output to the command "sh inventory raw". See if the PoE daughter card is found in the list. If not, your other option is to remove the lid and peer inside.
11-10-2014 02:36 PM
No power supply is available for the router so it can't be powered on to issue the command.
So what if a 125W power supply is connected and there is no daughter card installed? Will the router work with the 125W power supply and no PoE daughter card?
Regards.
11-10-2014 04:01 PM
I need to point out I've never done this before. All our routers were pre-ordered with PoE daughter card.
If I was to hazard a guess, the answer is yes. The router will operate with the 125w PS.
07-14-2015 11:42 AM
I just had to go through this as well and posted photos (with SKUs) of the parts for those that want to know exactly what is needed. Here is the parts list:
800-IL-PM-4= - PoE Daughter-card
PWR-125W-AC - 125W power supply
50-1807-02-A0 - standoffs with two notches
50-1700-01-A0 - standoff with one notch
48-0421-01-A0 - 3 screws
