configuring auto failover for clients over two ethernet interfaces
olufunke1
we are an isp, we have clients that have two links from us these links are terminating on ethernet ports on our core switches(conected to the PE routers). The desire is to achieve an auto failover between between these two links for the clients, for clients on the MPLS platform their is no issue but the challenge are the clients using static routes on their network and are not ready to move to dynamic routing. Is there a way around this?
royalblues
Level 10
Level 10
You can do this by Using loopback address
create a lopback interface at both sides
Let the customer have the default route pointing to your loopback interface
similarly your route for the customer subnet should point to thier Loopback interface
Route the loopback IP primarily via one ethernet interface and backed up by the other
eg.
interface loopback 1
des " connected to customer network 100.100.100.0/24
ip address 1.1.1.1 255.255.255.255
int e0/0
ip address x.x.x.x y.y.y.y
int e0/1
ip route 100.100.100.0 255.255.255.0 1.1.1.2
ip route 1.1.1.0 255.255.255.252 ethernet0/0
ip route 1.1.1.0 255.255.255.252 ethernet0/1 20
Similar configuration on the customer side
HTH, rate if it does
Narayan
i will prefer to do dynamic on my own PEs because i have many clients and having static routes for each will be cumbersome.
i believe eBGP should do, using my own public AS in my network and private AS in the clients, but i need help on how to go about it.
There are lot of ways for doing this via BGP.
You can create a BGP relationship between the clients on the loopback address. Rest of the configurations will be same.
router BGP
neighbor remote-as
second approach would be to create 2 BGP relationship with the ethernet Ip address and use attributes like local preference, MED to influence routing. This would also require the client to do the same to influence his outgoing traffic
Narayan
