Configuring BGP on 4948
tdale1987
I have a 4948 running bootflash:cat4500-entservicesk9-mz.150-2.SG11.bin
ARIN just provided me my ASN and im trying to setup BGP or attempt to see how to set it up. In the first step im already at a road block.
hostname(config)#router bgp ?
  <1-65535>  Autonomous system number
My issue is my ASN is over 65535 as we all know those numbers are all taken. I converted my number with the decimal using http://submit.apnic.net/cgi-bin/convert-asn.pl
The issue i have now is it wont take it.
I get the following error:
hostname(config)#router bgp 1.11
% Invalid input detected at '^' marker.
I'm running a 15.x iOS image so why isnt it accepting it. Can't figure this out. I never setup BGP before so be gentle haha.
Thanks in advance!
Tom
Congratulations on finding the answer to your own problem. And thanks for posting back to the forum confirming that Jon pointed you in the right direction. +5 for you.
Rick
Rick
8 Replies 8
johnd2310
Level 8
Level 8
Have you guys tried adding the following command to your bgp configuration:
bgp asnotation dot
thanks
John
**Please rate posts you find helpful**
John,
(config)#bgp asnotation dot
(config)#router bgp asnotation dot
Its not letting me setup the bgp because i cannot input my as as it is higher than what its allowing me: <1-65535>.
How can i add that to my BGP config if this is my first BGP profile.
Tom
Tom
The first mention of that feature for your switch is in the following release notes -
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_26677-01.html
so looks like you need to upgrade.
Jon
Jon,
This is for the 4948E. I have the non E series. as you can see in my post im running:
if i had the E series i would be running 'cat4500e'
According to Cisco's website these are what i can have:
15.0.2-SG11(MD)
12.2.54-SG1(ED)
12.2.31-SGA11(ED)
These are the "latest releases" for the 4948. Any help on what i need would be greatly appreciated!
Tom
Tom
I think you may be out of luck because as far as I can tell the same applies to those versions of software  ie. you need a later release.
However I cannot open all the release notes for the versions you list for some reason so here is the link -
http://www.cisco.com/c/en/us/support/switches/catalyst-4500-series-switches/products-release-notes-list.html
and then you can search for "BGP".
I don't think you will find any mention of that feature until you check the release notes for version 15.1(1)SG but you say you cannot use that version with your switch.
Jon
Jon,
Bad news, 4-byte ASNs is NOT supported by my switch.
4948 according to the cisco feature list is not listed.Oh cisco why :(
Tom
Tom
Rick
Rick
Everyone thank you!
I was able to make a ticket with ARIN and switch my 4-byte ASN for a 2-byte ASN. This solved my issue with BGP but if i was able to switch my ASN i would of had to buy a new switch to do BGP.
Thanks again!
