Configuring Cisco 1801 router for PPPoE
Rabnawaz Anwar
we have cisco 1801 router and want to configure for PPPoE.As our ISP has provided adsl connection having following settings:
Encapsulation:  PPPoE
Multiplexing:  LLC based
VPI = 0
VCI = 103
Login =xxxxx
Password =xxxxx
IP:  dynamically from ISP
I am new to configure cisco router.Please tell us complete steps for configuring cisco router 1801 for above configuration.
Hi Rabnawaz,
Thank you! Please add the following commands to your configuration after replacing the YOUR_LOGIN and YOUR_PASSWORD with your true ISP credentials (enter the configuration mode first using the enable and configure terminal commands):
ip routing
ip cef
interface atm0
no shutdown
pvc 0/103
  pppoe-client dial-pool-number 1
interface dialer0
dialer pool 1
encapsulation ppp
ppp pap sent-username YOUR_LOGIN password YOUR_PASSWORD
ppp chap hostname YOUR_LOGIN
ppp chap password YOUR_PASSWORD
ppp ipcp dns request accept
ip address negotiated
ip nat outside
ip mtu 1492
ip tcp adjust-mss 1452
interface vlan1
ip nat inside
no shutdown
ip access-list standard NAT
permit 192.168.1.0 0.0.0.255
ip nat inside source list NAT interface dialer0 overload
ip route 0.0.0.0 0.0.0.0 dialer0
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool LAN
network 192.168.1.0 /24
default-router 192.168.1.1
import all
This configuration should
  1. connect to your ISP using the login and password you were assigned (replace the YOUR_LOGIN and YOUR_PASSWORD with your true credentials for the ISP connection)
  2. start assigning addresses to LAN clients from the IP network 192.168.1.0/24, starting with 192.168.1.11
  3. perform necessary Network Address Translation to allow internet access
Please try it out and let me know if it worked. Thank you!
Best regards,
Peter
7 Replies 7
Peter Paluch
Hello Rabnawaz,
Configuring the 1801 router for PPPoE access to DSL should be fairly easy. However, to know how the interfaces on your 1801 router are currently named and numbered, can you capture the entire output of the show running-config command and post it here?
Thank you!
Best regards,
Peter
Here is the configuration:
Current configuration : 1460 bytes
version 12.4
hostname JSRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$9fud$zjln8FSnh0hNR8TVxcIqp.
enable password xxxxxx
no aaa new-model
dot11 syslog
no ip routing
no ip cef
archive
log config
  hidekeys
interface ATM0
no ip address
no ip route-cache
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface BRI0
no ip address
encapsulation hdlc
no ip route-cache
shutdown
no cdp enable
interface FastEthernet0
no ip address
no ip route-cache
speed auto
full-duplex
no cdp enable
interface FastEthernet1
shutdown
no cdp enable
interface FastEthernet2
shutdown
no cdp enable
interface FastEthernet3
shutdown
no cdp enable
interface FastEthernet4
shutdown
no cdp enable
interface FastEthernet5
shutdown
no cdp enable
interface FastEthernet6
shutdown
no cdp enable
interface FastEthernet7
shutdown
no cdp enable
interface FastEthernet8
shutdown
no cdp enable
interface Vlan1
no ip address
no ip route-cache
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password xxxxxx
login
no process cpu extended
no process cpu autoprofile hog
end
Hi Rabnawaz,
ip routing
ip cef
interface atm0
no shutdown
pvc 0/103
interface dialer0
dialer pool 1
encapsulation ppp
ip nat outside
ip mtu 1492
interface vlan1
ip nat inside
no shutdown
ip dhcp pool LAN
import all
Best regards,
Peter
Yes it works!!!!!!!!!!!!!!!!!!! Thanks.
But  how to check bandwidth  from cisco router and also its logs to confirm that is everything is ok?
I have checked internet speed from website speedtest.net and it gives about download 0.8 Mbits/sec and upload 0.4Mbits/sec.However my internet connection is 2Mbits/sec.Also how to verify it from checking directly from router.
Also in case of any failure in internet connection.How to check router logs to find out reason of failure.
You are welcome.
Regarding the connection speed - try issuing the show dsl interface atm 0 and post the results here. This command displays information about the physical parameters of the DSL connection. Some vital information may be present there. Also, in general, the pages that measure the alleged speed are often notorious for being imprecise. Try downloading a large file from a server that has no performance bottlenecks itself, for example:
http://www.kernel.org/pub/linux/kernel/v3.0/linux-3.4.5.tar.bz2
In general, it is not possible to verify the download speed from the router itself. The router can tell you about the operation mode of the DSL line and about selected parameters that affect its speed limits, however, performance tests have to be done from a standalone PC.
Regarding the logging, again, the router is not going to store detailed infomation about why the connection failed. In many cases, it does not even know. It is up to you to use various show and debug commands to narrow down the possible cause of the outage.
Would you mind posting your current configuration again? Remove the passwords, though.
Best regards,
Peter
Hi guys,
i'm too i have my speed low, after configure my 1801, normaly the speed average is around 10 to 9 mbps, but with  cisco router the max speed that we get is 6 to 7 mbps, do you have any idea?
Best regards
Cahrlie.
Hi thank you
it's working even with ROUTER cisco 800.
Thank you for the configuration.
have a good day.
