Configuring cisco 3560v2
okoroji80
I just procured    Cisco 3560V2- 48PS-S i would like to know how to set it up from scratch:
1. configuring passwords: enable and priviledge
2. Creat Vlan , such that systems connected to the Vlan can connect to internet.
3. enable routing protocols
4. How do i use the switch as a default gateway for the systems on the vlan
5. how do i make sure the desktops connected to the switch are browsing the internet.
Reza Sharifi
What is the network looks like?  How many devices do you have?
Are you planning to use the switch as a router or you have router to do the routing for you?
how many vlans you plan to have?
Pawan Sharma
What I understand from your post is that you need configuration for the new switch. Well in that case you can send me all your LAN details or a network diagram or your requirements and i can try to do it for you.
Pawan Sharma
http://www.ebrahma.com
Pawan Sharma
https://itgears.io
paolo bevilacqua
Are you the end user? From your questions seems like you have much confusion about networking, and are using common terms without know their actual meanin and applicaibility.
In that case your best choice would be to engage a reputable consultant, or certified Cisco Partner.
Otherwise, you risk wasting many hours studying and not even get good results.
