Configuring privilege issue
nomanbari
I need some help here. I am trying to configure a router for access privileges.
Following is the configuration:-
enable secret level 14 5 $1$yQtt$0yL38AHKDnpuLO3MMaGi3/
privilege configure level 14 interface
privilege configure level 14 interface shutdown
privilege configure level 14 interface no shutdown
privilege configure level 14 interface ip address
privilege configure level 14 interface no ip address
privilege exec level 14 show run
privilege exec level 14 configure terminal
privilege exec level 14 show startup
Problem is that though user can login in access level 14 but he faces two issues:-
1. sh run output is appears only as
Building configuration...
Current configuration : 80 bytes
interface Tunnel0
interface FastEthernet0/0
interface Async5
end
But sh startup is completely shown with all the information.
2. User can enter interface config mode but if he tries to configure ip address or shutdown interface, it doesn't work.
Any help will be greatly appreciated.
--Noman Bari
8 Replies 8
anton.elita
Hi Noman,
"sh run" actually shows you what you can configure.
"sh start" shows the contents of the startup file in flash.
Hence, you need to give the user "configure" privilege, in order to let him view running-config.
An option for viewing running-config would be creating another user with auto-command "show running" (and automatic logout).
Best regards,
Anton Elita
Hi Anton,
Thank you for your response. I tried adding configure command (after I posted here) but the problem persists. I added
privilege exec level 14 show running-config
but still level 14 user can't see the running configuration neither he can change interface configuration (the things that i have allowed him to do as shown in my earlier posting) but he can enter the interface configuration mode.
Help will be greatly appreciated.
--Noman Bari
Just resolved one issue..Added these
privilege interface level 14 shutdown
privilege interface level 14 ip address
but the issue of seeing running conf remains : )..
--Noman Bari
Hi Noman,
user with "not-15" privilege level sees in running config only what he/she can modify.
please check the link:
http://www.cisco.com/en/US/customer/tech/tk59/technologies_tech_note09186a00800949d5.shtml
best regards,
Anton Elita
rajinikanth
Level 3
Level 3
Try to create a user at global config
username name privilege [level]
Check this link
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800ca7cd.html#wp1029432
Hope it helps you
Raj
Hi Raj,
i have resloved one major issue regarding configuring interface but if u can help me with show run command execution then that will be great...
--Noman Bari
rajinikanth
Level 3
Level 3
Instead of this command
Try to use
privilege exec level 14 show run full
Tell me if this change worked.
Raj
Hi Raj,
Thanks for the suggestion..but I figured out that i was doing the right thing but missing one important point..the thing is since i have configured level 14 user to configure the ip address in interface mode, in the sh run (while in level 14) shows me interfaces with ip address only... if i add say
privilege configure level 14 interface description
then in sh run description shows along with the ip address for each interface...basically its giving a restricted view and it meets my design requirement(i removed privilege exec level 14 show startup )...so this is great but thanks so much for your helping out and giving your precious time...really appreciate that...
--Noman Bari
