Configuring telnet user in cisco 2811 router
marstelecom
Hi recently we purchased Router 2811 and i need to configure telnet user for vty 0 4 and vty 5 15 with password being encrypted. Im new to the Cisco Router Config. SO i request someone to help me out.
6 Replies 6
spremkumar
Level 9
Level 9
you can create the access password using password command under the line config and make sure that you use service password-encryption in the global config so that the password you enter may not appear as it is.
I would suggest you to use privilege levels with AAA enabled so that you can be assured that only authrorized personnel can do the config changes/modifications.
regds
Do you have those commands on your finger tips, im unable to get the documentation for the Router
Pravin Phadte
Level 5
Level 5
config t
service password-encryption \
[this will encrypt all the passowrd which are typed in clear text]
line vty 0 4
login (local or tacacs)
password cisco [this is non encrypted]
or
password secret cisco
The line vty is encription 7 which can be decripted.
smohanasundaram
you can use the following configurations.
router#config t
router(config)#service password encryption
router(config)# username test password "your password"
router(config)# username test privilege " whatever you want 0 to 15"
router(config)#line vty 0 4
router(config-line)#transport input telnet
router(config-line)#transport output telnet
router(config-line)#login local
router(config)#line vty 5 15
router(config-line)#end
router#wr
Thanks and regards
S.Mohana sundaram
INDSYS Technologies
Thanks Mr.Sundaram, I just go one step ahead and ask that for my Jrs I wanted to just give them Level -1 access for which i need to give them a different username and password. What would would be my line configs in that case.
Prasanna Sastry.G
Mars Telecom
Hi Prasanna
add the following configuration
router#config t
router(config)#username prasanna password test321 # Change this password( test321) whatever you want
router(config)#username prasanna privilege 1 # this line helps prasanna user privilege as 1
router(config-line)#exit
router#wr
its solves your needs.
Please Rate this post if helps
Thanks and Regards
S.Mohana sundaram
INDSYSS Technologies
+91 98940 44411,mohans@indsys.co.in
