Configuring VDSL on Cisco 897-VA K9
somehow00
Hi.
I'm trying to setup Cisco 897-K9 for my VDSL internet connection with dynamic IP (if I will successful then I’ll order a /29 IP prefix).
I was checking different configurations but no of them work.
Some people say I need to put for interface ATM0:
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  pppoe-client dial-pool-number 1
Others that interface ATM0 should be with no config and shutdown.
Also same with subinterfaces:
1).
interface ATM0.3 point-to-point
 description Netia
 pvc 8/35
  encapsulation aal5snap
  pppoe-client dial-pool-number 3
2).
interface Ethernet0.101
 encapsulation dot1Q 101
With route or wiuthout route (ip route 0.0.0.0 0.0.0.0 Dialer1)
I’m really confused. Anyone can tell me how to configure it properly to make it work? Maybe it's the fault of my Controller firmware or something else
Info from my ISP (NETIA) about my line:
VDSL line
VPI: 8
VCI: 35
Multiplexing: LLC
Encapsulation: PPPoE
(Cable with rj11)
Modem firmware: VA_A_39m_B_38h3_24h.bin
Router#show controller vdsl 0
Controller VDSL 0 is UP
Daemon Status:           Up
                        XTU-R (DS)              XTU-C (US)
Chip Vendor ID:         'BDCM'                   'IFTN'
Chip Vendor Specific:   0x0000                   0xB203
Chip Vendor Country:    0xB500                   0xB500
Modem Vendor ID:        'CSCO'                   '    '
Modem Vendor Specific:  0x4602                   0x0000
Modem Vendor Country:   0xB500                   0x0000
Serial Number Near:    FCZ201790ZL C897VA-K 15.7(3)M4a
Serial Number Far:     5502610891
Modem Version Near:    15.7(3)M4a
Modem Version Far:     0xb203
Modem Status:            TC Sync (Showtime!)
DSL Config Mode:         VDSL2
Trained Mode:   G.993.2 (VDSL2) Profile 17a
TC Mode:                 PTM
Selftest Result:         0x00
DELT configuration:      disabled
DELT state:              not running
Full inits:             1
Failed full inits:      0
Short inits:            0
Failed short inits:     0
Firmware        Source          File Name
VDSL            embedded        VDSL_LINUX_DEV_01212008
Modem FW  Version:      4.14L.04A
Modem PHY Version:      A2pv6C039t.d24o_rc1
Trellis:                 ON                       ON
SRA:                     disabled                disabled
 SRA count:              0                       0
Bit swap:                enabled                 enabled
 Bit swap count:         1                       0
Line Attenuation:        23.9 dB                  0.0 dB
Signal Attenuation:       0.0 dB                  0.0 dB
Noise Margin:             9.2 dB                  9.0 dB
Attainable Rate:        33566 kbits/s            5940 kbits/s
Actual Power:            13.2 dBm                 7.6 dBm
Per Band Status:        D1      D2      D3      U0      U1      U2      U3
Line Attenuation(dB):   18.4    45.8    71.1    8.5     36.9    56.5    N/A
Signal Attenuation(dB): 18.3    45.3    N/A     8.5     36.7    55.5    N/A
Noise Margin(dB):       9.2     9.3     N/A     9.4     9.0     9.0     N/A
Total FECC:             0                        0
Total ES:               0                        0
Total SES:              0                        0
Total LOSS:             0                        0
Total UAS:              38                       38
Total LPRS:             0                        0
Total LOFS:             0                        0
Total LOLS:             0                        0
                  DS Channel1     DS Channel0   US Channel1       US Channel0
Speed (kbps):             0            30547             0              5492
SRA Previous Speed:       0                0             0                 0
Reed-Solomon EC:          0                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Interleave (ms):       0.00             8.00          0.00              8.00
Actual INP:            0.00             2.00          0.00              1.10
Training Log :  Stopped
Training Log Filename : flash:vdsllog.bin
19 Replies 19
marce1000
 - Here's a YouTube example video , you may find it informational or helpful :
                 https://www.youtube.com/watch?v=meLtRs_GEUE
 M.
Video showing how to configure a Cisco 887 router for VDSL (based on a BT Infinity service - UK) 1. VDSL Interface and subinterface interface Ethernet0 no ip address interface Ethernet0.101 encapsulation dot1Q 101 pppoe enable pppoe-client dial-pool-number 1 2.Shut down the ATM interface and ...
balaji.bandi
here is the standard config : ( test and advise, still an issue, post the complete config)
https://katystech.blog/2020/12/fttc-vdsl-on-a-cisco-897va/
BB
Unfortunately, it's not working. I've skipped the configuration of passwords, ssh, and NAT.
Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
ATM0                       unassigned      YES unset  administratively down down
BRI0                       unassigned      YES unset  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
Dialer0                    unassigned      YES manual up                    up   <— on the blog it’s <ext-IP-address> and IPCP under Method
Ethernet0                  unassigned      YES unset  administratively down down
Ethernet0.101              unassigned      YES unset  administratively down down
GigabitEthernet0           unassigned      YES unset  down                  down
GigabitEthernet1           unassigned      YES unset  down                  down
GigabitEthernet2           unassigned      YES unset  down                  down
GigabitEthernet3           unassigned      YES unset  down                  down
GigabitEthernet4           unassigned      YES unset  down                  down
GigabitEthernet5           unassigned      YES unset  down                  down
GigabitEthernet6           unassigned      YES unset  down                  down
GigabitEthernet7           unassigned      YES unset  down                  down
GigabitEthernet8           unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
Vlan1                      192.168.1.254   YES manual down                  down
It's my complete running-config (I only changed 192.168.1.254/24 to make it work with my current network devices):
Current configuration : 2490 bytes
! Last configuration change at 13:42:26 UTC Sun Jan 24 2021
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp pool LAN
 network 192.168.1.0 255.255.255.0
 dns-server 9.9.9.9
 default-router 192.168.1.254
ip cef
no ipv6 cef
license udi pid C897VA-K9 sn FCZ201790ZL
redundancy
controller VDSL 0
interface ATM0
 no ip address
 shutdown
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface Ethernet0
 no ip address
 shutdown
 description PPPoE VLAN101
 no ip redirects
 no ip proxy-arp
 ip virtual-reassembly in
 pppoe enable group global
interface GigabitEthernet0
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 no ip address
 shutdown
 duplex auto
 speed auto
interface Vlan1
 ip address 192.168.1.254 255.255.255.0
interface Dialer0
 mtu 1492
 ip address negotiated
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 encapsulation ppp
 ip tcp adjust-mss 1452
 dialer pool 1
 dialer-group 1
 ppp authentication pap chap ms-chap callin
 ppp chap hostname xxxxxx@xxxxxx.xx
 ppp chap password 0 xxxxxxx
 ppp ipcp address accept
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list standard LAN
 permit 192.168.1.0 0.0.0.255
ipv6 ioam timestamp
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
end
balaji.bandi
i prefer to see full current running-config removing any passwords. the main part NAT config which required.
also, post-show ip interface brief
BB
I've already posted show ip interface brief - it's on the top of my last replay.
Sorry, I meant that I didn't type on the console configuration for hostname, user/password access, ssh, and NAT. I've shown my full running-config. If It's necessary to launch NAT to make vdsl connection to work , here it is:
Current configuration : 2645 bytes
! Last configuration change at 14:39:38 UTC Sun Jan 24 2021
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
dns-server 9.9.9.9
no ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip redirects
no ip proxy-arp
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxx@xxxx.xx
no ip http server
ip nat pool LAN 192.168.1.0 192.168.1.254 netmask 255.255.255.0
ip nat inside source list LAN interface Dialer0 overload   <--- I have also tryed with: ip nat inside source list LAN interface Ethernet0.101 overload
ipv6 ioam timestamp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
I think on the 897, the subinterface goes on interface GigabitEthernet8. Try the config below (important parts marked in bold
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
dns-server 9.9.9.9
--> ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
--> interface GigabitEthernet8.101
--> encapsulation dot1q 101
--> pppoe enable group-global
--> pppoe-client dial-pool-number 1
no ip address
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
--> ip nat inside source list 1 interface Dialer0 overload
--> ip route 0.0.0.0 0.0.0.0 Dialer0
--> access-list 1 permit 192.168.1.0 0.0.0.255
--> dialer-list 1 protocol ip permit
ipv6 ioam timestamp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Heya,
Something has changed when show ip interface brief but still no ping to the internet, same from Compuyer behind the NAT.
Two commends didn't pass for interface GigabitEthernet8.101. I'd bold them.
Router# show ip interface brief
ATM0                       unassigned      YES NVRAM  administratively down down
BRI0                       unassigned      YES NVRAM  administratively down down
Ethernet0                  unassigned      YES NVRAM  administratively down down
GigabitEthernet8           unassigned      YES NVRAM  administratively down down
GigabitEthernet8.101       unassigned      YES unset  administratively down down
NVI0                       unassigned      YES unset  up                    up
Router#
Router#show run
Building configuration...
Current configuration : 2512 bytes
! Last configuration change at 18:12:16 UTC Sun Jan 24 2021
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
dns-server 9.9.9.9
ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
shutdown
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
<—- Router(config-subif)#duplex auto
<—- % Invalid input detected at '^' marker.
<—— Router(config-subif)#speed auto
<—— % Invalid input detected at '^' mark
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxx@xxx.xx
no ip http server
ipv6 ioam timestamp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
you need to 'no shut' interface GigabitEthernet8:
Router#conf t
Router(config)#interface GigabitEthernet8
Router(config-if)#no shut
Now in the config it's:
no ip address
duplex auto
speed auto
But anyway it's down:
Router#show ip interface brief
Dialer0 unassigned YES NVRAM up up
GigabitEthernet8 unassigned YES NVRAM down down
GigabitEthernet8.101 unassigned YES unset down down
Vlan1 192.168.1.254 YES NVRAM down down
Router#
on which port is the ISP/cable modem connected ? Is that GigabitEthernet8 ?
it’s not connected from the ISP modem but straight from the line to “vdsl/adsl over POTS” Rj11 port.
try the ATM interface configuration marked in bold:
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
dns-server 9.9.9.9
--> ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
--> ip nat outside
--> ip virtual-reassembly
--> pvc 8/35
--> encapsulation aal5mux ppp dialer
--> dialer pool-member 1
--> dsl operating-mode auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
interface Ethernet0
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no ip http server
ipv6 ioam timestamp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
Thank You for still having patience for this.
Router(config-if)#do show ip int brie
ATM0                       unassigned      YES NVRAM  down                  down
GigabitEthernet8.101       unassigned      YES unset  deleted               down
Virtual-Access2            unassigned      YES unset  up                    up
Router(config-if)#
Here is runnning-config:
Current configuration : 2436 bytes
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool LAN
dns-server 9.9.9.9
ip cef
no ipv6 cef
redundancy
controller VDSL 0
interface ATM0
no ip address
ip nat outside
pvc 8/35
<—— Router(config-if)#dsl operating-mode auto
<—% Invalid input detected at '^' marker.
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Ethernet0
no ip address
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
interface Dialer0
mtu 1492
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname jfthfojf@bn24.pl
no ip http server
ipv6 ioam timestamp
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
end
we are missing something fundamental. What country are you in, and who is your ISP ?
