confused on access list
shiva_ial
can anyone tell me with scenario
where should i place inbound access list
or outbound access list particularly i need direction
simple way to apply it
rajivrajan1
Level 3
Level 3
sit inside the router and think about the packet movement.
so u will find.
mohammedmahmoud
Level 11
Level 11
ACL are applied either for inbound or the outbound traffic on an interface using:
ip access-group in
or
ip access-group out
Inbound access lists apply to traffic as it enters an interface.
Outbound access lists apply to traffic as it exits an interface.
The whole idea is whether you want to filter inbound packets or outbound packets.
Kindly check this document:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080100548.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
