connect multiple sites VPN with Firepower ( design )
Hisoma Sama
i have some clients site where all will be connected to one switch and connect to main site with firepower which managed with FMC
whats the best design in this scenario
my thoughts will be using /30 subnet from client side to firepower
middle switch will be separate vlan to each client
from firepower side since there is only one cable connect to middle switch will use subinterface
then site-to-site VPN
is this the best design or there is something better
7 Replies 7
If you are in control of the addressing, I would always use at least a /29. That gives you more flexibility if you want to add a HA-device at a later time.
From your description, I do not see why you would need a sub-interface on the devices. The main-interface should do it perfectly fine.
With only one cable (and without using any extra switch) you will likely run version 6.7 to be able to manage the FTD on the Data-Interface.
Hi Karsten
thanks for your reply
i didnt get how I can make it without subinterface as there are different client each will have different IP ( can you advise more into this)
Then I actually don't really get what you are trying to achieve.
sorry my mistake for not describing well
check photo attached i have different client to connect site-to-site vpn to HQ site
each client is different and should not have access to each other only to HQ site
Ok, this is actually what I understood. With this design you can do L3 routing on the "Site D" switch and put each link to sites A, B and C in it's own Access-VLAN. The FTDs don't need a sub interface with that. You only need a sub interface if you want to use a trunk between the Switch and the Sites.
For the access-control that no client can access-other clients, you typically configure the Access-List on each FTD accordingly.
i was more thinking that the trunk will be between SW and FP
so subinterface from FP side as it will be trunk
is there any pros/cons for this?
Using an Access-interface to a single customer is more "typical", it's slightly more config on the firewall-side for trunk but should be ok in general.
