connecting 3 sites
tallpaulroe
i need a little help in connecting 3 sites
site A  10.x.x.x networks
site B 192.168.x.x  networks
site C 192.168.x.x networks
we also need to connect over the internet
site A has around 30 devices that will send data to a server at site B
site B has a server that will from time to time request data from the devices at Site A
Site D needs to access the devices at Site A for development support only
my thoughts were that i need static NAT for the 30 ish devices at Site A
then a 2 VPN's from site A to site's B and C.
so i kind of thought that i would end up with this kind of setup
site A 10.x.x.x--R1(doing Static NAT)--Firewall/Router------Internet-------Firewall/router---R2(doing Static Nat)---Site C 192.168.x.x
        |__Firewall/router----R3(doing static NAT)--- Site B 192.168.x.x
am i heading in the right direction??
5 Replies 5
mvsheik123
Level 7
Level 7
As you already figured this out, your best best bet would be VPN. If the VPN tunnel is UP, you do not need static NAT for the IPsto reach the other site . (only if they need to goto internet- then you can think about it, provided you got enough public IPs). Also, for side D - make sure to include only developement subnet at siteA in the interesting traffic ACLs. All the best.
Thx
MS
Marwan ALshawi
The best and easiest way is to use DMVPN
This will let you have a hub and spoke topology over the Internet with multipoint gre tunnels protected by IPSec for security
Also these mgre tunnel let you have multicasting and dynamic routing to be run between your sites for full connectivity
Also you can have only one public static ip over internet on the hub
And spoke to spoke can go direct without going through
The hub
Please search
Google or cisco.com about DMVPN
If helpful rate
could i do this with an ASA at each site?
NO you need a router
however if you have ASA connected to the Internet and a router behind it then you can do NAT and ACL permitting GRE to the router inside the LAN
if you do not have rouer in each site only ASAs then you can use cleint server VPN also know as easy VPN on the ASA
http://tekcert.com/blog/2011/03/17/asa5510-asa5505-easy-vpn-server-client-configuration-sample
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/ezvpn505.html
if helpful Rate
