08-15-2011 01:46 AM - edited 03-04-2019 01:16 PM
i have a cisco 1921 router and it has ge0/0 (LAN) and ge(0/1) WAN.
ge 0/0 is well connected and i can ping it and the LED light is on but ge 0/1 has failed to come up.Ge0/1 is connected to an IDU and has a public IP address. The LED light also does not light on ge 0/1.Where could the problem be?
Agaba G
08-15-2011 02:00 AM
hi agaba,
kindly post your sh int g0/1 output. make sure g0/1 and IDU is on the same subnet. try changing UTP cable and test again.
08-15-2011 02:19 AM
Thanks John
Let me the sh int g/0/1 config to you shortly .Actually the ip address of g/e 0/1 will be the first ip that the idu(from ISP) can access because the cable is directly connected to the router .Meanwhile as i get the config, could a straight through or crossover be a problem?
08-15-2011 03:09 AM
Hi Agaba,
It could be a Layer 1 issue. You can try using a straight cable.
Basically, cross cable is used to connect two different network devices, i.e. router-router or switch-switch.
08-16-2011 11:28 PM
i get the below error when i paste the ge/0/1 config .
"This message can not be displayed due to its content. Please use the Contact Us link with any questions. "
08-17-2011 05:31 PM
hi,
can try uploading or attach your config (remove sensitive info)? not sure whether CSC have any issue.
