10-03-2011 07:34 PM - edited 03-04-2019 01:48 PM
In regards to a WAN connection, how would you recommend we connect a leased campus to our existing network. It is a temporary location that must be connected for a year.
We have an available 3845 with a VWIC2-2MFT-T1/E1 card.
We are supposed to be getting 2-T1 lines from Verizon.
We need to support data and voice, not so sure about video.
Additional information:
I have a spare 3750 L3 switch for the core and 6 access switches.
10-10-2011 02:30 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Are you asking something specific about "temporary" (i.e. for a year) connections or are you asking whether dual T1s with the equipment you've noted is sufficient?
If the former, unclear why "temporary" would make much of a technical difference. It might make a difference regarding contractional commitments.
If the latter, without knowing expected traffic volumes, unable to recommend whether your equipment is adequate, but a 3845 can easily handle dual T1s. It also supports an extensive QoS feature set.
For a LAN core the 3750 might or might not be fine; probably the former if there's only six other access switches. Again, though, without knowing what's the expected traffic, can't say this with much certainty. Also, there are many models of 3750s.
