Connecting two Routers using E1
Kaushik Ray
Hello I intend to connect up to routers back to back using E1.
I am about to prepare a cable for that.
I have found that the adviced cable for it is as below: can someone confirm this is correct please?
http://support.red-fone.com/downloads/tools/T1-E1_Crossover_Cable.bmp
Many Thanks in advance.
Kaushik
paolo bevilacqua
No. E1/T1 cable uses only 4 pins, that is, two pairs.
5 Replies 5
paolo bevilacqua
Thanks Paolo
Do you have a link for the pinouts which I could refer to please?
The interface is
VWIC3-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Paolo
Did you mean to say the following? I think the first drawing essentialy shows the same pinout?
Yes. But use two pairs only.
Thanks for the nice rating and good luck!
