connectivity idea required
alap84
can any one guide how to connect two differnt regional site on same city VIA dark fiber.
currently one site is running OSPF and other is also but dont know the IP scheme on other end. what is the best possible solution to connect both the sites either Dark Fiber or any thing else ....
what is the best possible way ... thanks in advance
Giuseppe Larosa
Hello Muhammad,
you simply need a common IP subnet and you will be able to run OSPF over it in the mean time
As a start you can think of using a BGP session with each side advertising its routes in BGP
when addressing plan will be clear you can move back to OSPF only.
Hope to help
Giuseppe
