02-04-2013 06:27 AM - edited 03-04-2019 06:55 PM
hi,
the remote site I would get on the internet that already exists on the site itself even
to avoid to connect via the internet Wan
02-04-2013 08:42 AM
Can you please describe the issue a bit detailed?
Alex
02-05-2013 01:27 AM
hi,
our application are centralized , in the remote site the user accede an application to use the connexion wan even the internet so, this remote site has another mode of connexion via the telephone line ,
if possible all the user of this remote site use the internet by this mode of connexion , to avoid to pass by the wan
we are cisco 3560 (level 3)
thanks
02-05-2013 02:17 AM
Hi Sakina,
Use a default route the router on which all lan traffic is co0ming in and this default route should be pointed towards the internet internet router or else use a default route on ur 3560 so it will get installed in Routing table and prefer first instead of dynamically learned default route.
Hope this will be helpful to u.
**Dont forget to rate the helpful answers.********
