NAT'd Subnet and Public Subnet on Same vLAN
matthewbutt
Hi All,
I hope this finds you well. A quick message to pick your brains if I may with a current issue I have on my Cisco 2921 router.
In short, we have two physical interfaces - one internal (0/2), one external (0/0). The internal interface has several sub-interfaces of which one has a Public Subnet applied to it (0/2.100), and another sub-interface has a NAT'd Subnet applied to it (0/2.101).
The traffic from the NAT'd subnet (0/2.101) appears online as the Public IP Address on the first physical inteface (0/0), as expected, when you lookup your Public IP Address online. We need to move this NAT'd Subnet to appear as one of the Public IP Addresses from within the other sub-interface (0/2.100).
My question is, how would I achieve this. This is the current configuration including the two physical interfaces, and the two sub-interfaces:
interface GigabitEthernet0/0
ip address 31.210.XX.XX 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2.100
encapsulation dot1Q 100
ip address 31.210.XX.XXX 255.255.255.240
interface GigabitEthernet0/2.101
encapsulation dot1Q 101
ip address 192.168.1.254 255.255.255.0
ip nat inside
To summarise, we would like the NAT'd sub-interface (0/2.101) to use one of the IP Addresses in the other sub-interface (0/2.100) as it's Public address. I hope that makes sense, thanks in advance for your help and of course ask any further questions you may have!
All the best,
Matthew
you will have to create a nat pool to get the desired result.
sample configuration.
ip nat pool Net31 31.210.x.x 31.210.x.x netmask 255.255.255.240
ip nat inside source list 1 pool Net31 overload
access-list 1 permit 192.168.1.0 0.0.0.255
Abzal
Level 7
Level 7
Do you mean Port Forwarding? Still it's not clear what are you trying to achieve.
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
Hi Syed,
Excellent, that worked perfectly! Thank you very much.
Alll the best,
Matthew
