Control Plane Policy & VRF
Oleg Gnedykh
Hi ALL !!!
I created CPP and applied the service policy like "permit tcp host x.x.x.x any telnet" to it.
It work very nice if I haven't VRF.
But, ALL my users from VRF "USER" or "Manage" can telnet to router :-(
What can you suggest to me?
5 Replies 5
are you sure about this
Thanveer
"Everybody is genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is a stupid."
Hi Muhammad !!!
No of course :-)
I created ACL   "permit tcp ANY ANY  telnet"
Then some class like "match access-group name my_acl"
Then I created policy like that
policy-map ctrl
class permitctrl
police 32000 conform-action drop exceed-action drop
And Then
control-plane
service-policy input ctrl
But I think it doesn't matter
It work very nice with simple IP, but not with VRF :-(
I read COPP and what I understood is its not interface level, its route processor level...
http://www.cisco.com/web/about/security/intelligence/coppwp_gs.html
To define appropriate policies for your CoPP configuration, you need to identify all of the traffic flows and packet rates for those flows that may be seen by CoPP. Typically, ACLs are used for the traffic flow identification task and, in most cases, the protocols as well as the source and destination IP addresses are well known. It is still quite likely that some surprise traffic flows will arise. The definition of these ACLs is one of the most critical steps in the CoPP process. MQC uses these ACLs to define the traffic classes, which in turn become the object of the policy actions (policing). Appropriate granularity in the distribution of protocols within these ACLs allows for better protection of the RP.
Management – ACL 121
! – ACL for CoPP Management class!
access-list 121 permit tcp <NOC block>  eq telnet
access-list 121 permit tcp  eq telnet  established
access-list 121 permit tcp   eq 22
access-list 121 permit tcp  eq 22  established
access-list 121 permit udp   eq snmp
access-list 121 permit tcp   eq www
access-list 121 permit udp   eq 443
access-list 121 permit tcp   eq ftp
access-list 121 permit tcp   eq ftp-data
access-list 121 permit udp   eq syslog
access-list 121 permit udp  eq domain
access-list 121 permit udp   eq ntp
Thanveer
Hi Oleg,
Did you have this sorted? Is the control-plane VRF aware? I'm facing similar issue. Any contribution is welcome.
Hi Oleg,
