controller card issues
mburguk1000
I have a issue where im trying to install a vwic-1mft-g703 card in a 1841 router. The router doesnt seem to recognise the controller when I go into interface mode. But from what i can see you can fo into configuration and then to card type which is e1. At the end of the config command you are presented with 0-0 card slot number. I just need some help as what ever slot number i enter it doesnt recognise it
Any help will be gladly appreicated
desai.jaideep
Level 5
Level 5
Can you give the output of
"sh ver"
"sh diag"
"sh run"
JD
spremkumar
Level 9
Level 9
hi
can you post the output of show verion and show controller commands here?
regds
