replacing 3600 router
wgranada1
I currently have an old 3640 router that I need to replace, the config is as follows:
IOS (tm) 3600 Software (C3640-IS-M), Version 12.2(26c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Mon 30-Jul-07 18:41 by ccai
Image text-base: 0x60008930, data-base: 0x6114B9D0
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
sfshkgrt1 uptime is 17 weeks, 4 days, 8 hours, 30 minutes
System image file is "flash:c3640-is-mz.122-26c.BIN"
cisco 3640 (R4700) processor (revision 0x00) with 59392K/6144K bytes of memory.
Processor board ID 17147854
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
MICA-6DM Firmware: CP ver 2740 - 4/10/2002, SP ver 2740 - 4/10/2002.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
2 Ethernet/IEEE 802.3 interface(s)
1 FastEthernet/IEEE 802.3 interface(s)
30 Serial network interface(s)
12 terminal line(s)
2 Channelized T1/PRI port(s)
1 Compression service adapter(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
I was thinking of replacing it with a 2921 with the following set up:
CISCO2921/K9
Cisco 2921 w/3 GE,4 EHWIC,3 DSP,1 SM,256MB CF,512MB DRAM,IPB
S29UK9-15104M
Cisco 2901-2921 IOS UNIVERSAL
NME-WAE-502-K9
WAAS Network Module For 2800, 3800 ISR - 1GB RAM, 120GB HDD
SF-WAAS-4.3-NM-K9
Cisco WAAS 4.3 NM SW image (separate license required)
WAAS-TRN-NM
Cisco WAAS Transport License for 1 Network Module
HWIC-2CE1T1-PRI
2 port channelized T1/E1 and PRI HWIC
HWIC-2T
2-Port Serial WAN Interface Card
PVDM2-12DM
12 Port Digital Modem Module
PVDM2-ADPTR
PVDM2 Adapter for PVDM Slot on Cisco 2900, 3900 Series ISR
SM-NM-ADPTR
Network Module Adapter for SM Slot on Cisco 2900, 3900 ISR
CAB-ACU
AC Power Cord (UK), C13, BS 1363, 2.5m
CAB-SS-V35MT
V.35 Cable, DTE Male to Smart Serial, 10 Feet
PWR-2921-51-AC
Cisco 2921/2951 AC Power Supply
ISR-CCP-EXP
Cisco Config Pro Express on Router Flash
MEM-2900-512MB-DEF
512MB DRAM for Cisco 2901-2921 ISR (Default)
MEM-CF-256MB
256MB Compact Flash for Cisco 1900, 2900, 3900 ISR
SL-29-IPB-K9
IP Base License  for Cisco 2901-2951
CON-CSSPD-2921
SHARED SUPP SDS Cisco 2921
Also do I really need the NME-WAE-502-K9 module?
Thank you in advance for you help!!
5 Replies 5
Leo Laohoo
What is more important is what is your WAN bandwidth?
I finally got in contact with my coworker in Hong Kong and got the specs....it is a a 512k with only 6
active customers so from that it appears what I have is good to go but minus the NME-WAE-502-K9 module
as their is really no need for WAN optimization for this.
512K????
Nuts.  I haven't heard of this kind of WAN bandwidth since 2005.  Couldn't you just settle for a xDSL line instead?
I guess if you want to do VoIP then the 2900 ISR G2 is the way to go.  With that tiny bandwidth, in my opinion, a WAAS would be nice to have.
I don't understand why, however, you need a V35 cable for.  How is the ISP terminating the link?  Couldn't the ISP terminate as RJ?
LOL yeah I know it is a 512k frame relay circuit....this connection is just for price files an there is only
like 6 users pulling these files I found out so  there is no voice or video or any high bandwidth application
on this.  Like you said the WAAS would be nice but in this case I think for what they use it  for is over kill.
But I apprciate your input on all this I actually found what the WAAS does yesterday(my friday) and after
reading it and finding out what they use this link for determined that we didn't really need this.  Thank you
for all your help on this!!!
LOL yeah I know it is a 512k frame relay circuit....this connection is just for price files an there is only like 6 users
Why not investigate the pricing for an xDSL line instead?
But I apprciate your input on all this I actually found what the WAAS does yesterday(my friday) and after reading it and finding out what they use this link for determined that we didn't really need this.
On the contrary, a WAN accelerator is perfect for a link like this.
