05-28-2024 10:58 PM
Could Destination Port Be VLAN in Port Mirroring on NCS5500? I saw failure messages as follows.
Monitor-session xxxx
Destination interface HundredGigE0/0/0/15.200
Session has not been set up in the hardware
Source Interface Dir Status
Hu0/0/0/17.200 Both Traffic may be replicated to the wrong destination
05-28-2024 11:18 PM
what IOS XR code running on device, can you able to post the relevant configuration and show monitor-session status detail
HundredGigE0/0/0/15.200 and Hu0/0/0/17.200 - i see both sub-interface are 200 (is this tag both same VLAN ?)
check some reference guide :
05-29-2024 06:38 AM
Thanks.
The version is "Cisco IOS XR Software, Version 7.7.2".
I am currently using VLAN tag 200 for both sub-interfaces for testing purposes. It would be more effective to use different VLAN tags for each sub-interface.
Here is the details of monitor-session from the router.
RP/0/RP0/CPU0:xxxx#show monitor-session status detail
Source Interfaces
HundredGigE0/0/0/17.200
Direction: Both
Port level: False
ACL match: Disabled
IPv4 ACL: Disabled
IPv6 ACL: Disabled
Portion: Full packet
Interval: Mirror all packets
Mirror drops: Disabled
Status: Traffic may be replicated to the wrong destination.
More details on the sub interfaces used in the port mirroring.
RP/0/RP0/CPU0:xxx-sw#show interfaces HundredGigE 0/0/0/15.200
Wed May 29 13:24:38.914 UTC
HundredGigE0/0/0/15.200 is up, line protocol is up
Interface state transitions: 1
Hardware is VLAN sub-interface(s), address is 94ae.f0dc.a83c
Layer 2 Transport Mode
MTU 9220 bytes, BW 100000000 Kbit (Max: 100000000 Kbit)
reliability Unknown, txload Unknown, rxload Unknown
Encapsulation 802.1Q Virtual LAN,
Outer Match: Dot1Q VLAN 200
Ethertype Any, MAC Match src any, dest any
loopback not set,
Last link flapped 07:42:17
Last input never, output never
0 packets input, 0 bytes
0 input drops, 0 queue drops, 0 input errors
0 packets output, 0 bytes
0 output drops, 0 queue drops, 0 output errors
RP/0/RP0/CPU0:xxx-sw#show interfaces HundredGigE 0/0/0/17.200
Wed May 29 13:27:02.001 UTC
HundredGigE0/0/0/17.200 is up, line protocol is up
Hardware is VLAN sub-interface(s), address is 94ae.f0dc.a844
loopback not set,
Last link flapped 07:44:40
05-29-2024 07:30 AM - edited 05-29-2024 07:30 AM
Hello @lzhang9 ,
try to use the physical interface as destination interface as reported in the examples in config guide provided by BB
Hope to help
Giuseppe
05-29-2024 07:40 AM
Thank you @Giuseppe.P93
It works if the destination port is physical interface. However, in my situation, using the VLAN tag is intentional.
BB mentions the version of 7.8.x while my version is 7.7.2. Is the VLAN destination port a new feature introduced since 7.8.1?
Release 7.8.1 | SPAN filtering of outgoing traffic on Layer 2 interfaces for Cisco NC57 line cards was introduced. |
05-29-2024 09:53 AM
Update:
I tried the same configuration on the NCS5700 routers and it works fine. So it looks like some constraint of NCS5500 hardware/software.
