Counter time on interfaces
mcardell
Good morning,
how do I change the way the traffic is counted in an interface?
I am thinking to the line from the show interfaces:
5 minute input rate 4000 bits/sec, 5 packets/sec
How do I modify the 5 minutes to 1 minute for example?
peterledwidge
Level 5
Level 5
Router#config t
Router(config)#int X
Router(config-if)#load-interval 60
Then you can set it back to 5 mins
Router(config-if)#load-interval 300
peterledwidge
Level 5
Level 5
Router#config t
