CRC and error in fast ethernet
osamoz
Dear all,
I'm facing lot of errors and CRC on LAN interface. any one can help to determine the problem where,
I'm connecting Fastethernet to Mentat accelator and then to PIX firewall. all interfaces touch the router configured full duplex and 100Mbps. any advice will be much appreciated.
interface FastEthernet0/0
ip address *.*.*.* 255.255.255.248 secondary
ip address *.*.*.* 255.255.255.224
no ip redirects
no ip proxy-arp
ip accounting precedence input
ip route-cache flow
ip policy route-map oracle-vip
load-interval 30
speed 100
full-duplex
no cdp enable
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 0008.a3b6.6860 (bia 0008.a3b6.6860)
Internet address is *.*.*.* /27
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:01:01
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 205000 bits/sec, 82 packets/sec
30 second output rate 587000 bits/sec, 86 packets/sec
5206 packets input, 1596894 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
946 input errors, 946 CRC, 93 frame, 0 overrun, 0 ignored
0 watchdog
5374 packets output, 4562932 bytes, 0 underruns
0 lost carrier, 0 no carrier
6 Replies 6
bella
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfd6.shtml#SpeedDuplex_mismatch
check cables lengths and integrity. also 100BaseTX/FX reported by sh int seems strange for me. is it a "twin port" where only one physical connector is active in any time? try to hardcode media for this int in that case.
here is hardware for F0/0
cable is showing amber this means there is a lost in cable or mismatching i confused now :)? but still 123 input errors, 123 CRC, 60 frame increased? Maybe missmatch with Mentat accelator?
sh controllers f0/0
Interface FastEthernet0/0
Hardware is AMD Am79c971
ADDR: 63D16774, FASTSEND: 60032A04, MCI_INDEX: 0
DIST ROUTE ENABLED: 0
Route Cache Flag: 203
LADRF=0x0000 0x0100 0x0000 0x0000
CSR0 =0x00000072, CSR3 =0x00001044, CSR4 =0x0000491D, CSR15 =0x00000180
CSR80 =0x00009900, CSR114=0x00000000, CRDA =0x0799AEE0, CXDA =0x0799B420
BCR9 =0x00000001 (full-duplex)
CSR5 =0x00000001, CSR7 =0x00000820, CSR100=0x0000F000, CSR125=0x00005C3C
BCR2 =0x00000000, BCR9 =0x00000001, BCR18 =0x000019E0, BCR22 =0x0000FF06
BCR25 =0x000000FF, BCR26 =0x00000080, BCR27 =0x00000010, BCR32 =0x00004480
HW filtering information:
Promiscuous Mode Disabled, PHY Addr Enabled, Broadcast Addr Enabled
PHY Addr=0008.A3B6.6860, Multicast Filter=0x0000 0x0100 0x0000 0x0000
amdp2_instance=0x63D17F24, registers=0x38000000, ib=0x799AB20
rx ring entries=64, tx ring entries=128
rxring=0x799AB80, rxr shadow=0x63D18190, rx_head=54, rx_tail=0
txring=0x799AFC0, txr shadow=0x63D182BC, tx_head=70, tx_tail=70, tx_count=0
Software MAC address filter(hash:length/addr/mask/hits):
0xC0: 0 0100.0ccc.cccc 0000.0000.0000 0
spurious_idon=0, filtered_pak=0, throttled=0, enabled=0, disabled=0
rx_framing_err=0, rx_overflow_err=0, rx_buffer_err=0
rx_bpe_err=0, rx_soft_overflow_err=0, rx_no_enp=0, rx_discard=0
tx_one_col_err=3, tx_more_col_err=16, tx_no_enp=0, tx_deferred_err=68
tx_underrun_err=0, tx_late_collision_err=0, tx_loss_carrier_err=0
tx_exc_collision_err=0, tx_buff_err=0, fatal_tx_err=0
hsrp_conf=0, need_af_check=0
tx_limited=0(64)
PHY registers:
Register 0x00: 2100 780D 7810 0003 0101 0000 0000 0000
Register 0x08: 0000 0000 0000 0000 0000 0000 0000 0000
Register 0x10: 0000 0000 4000 0000 3CFB 0010 0000 0002
Register 0x18: 0001 0000 0000 0000 0000
Some thoughts:
You state that all devices are configured for full duplex, but it looks to me like symptoms of a duplex mismatch still.
Double check the device that is on the other end of fa0/0 is set to full duplex.
Try setting fa0/0 to half duplex and watch the counters some more.
Is the other device maybe physically still at half even though the config says full?
Do they both operate fine when configured for half? (And give regular collision related errors?)
Thanks all,
I have tried to make it half duplex. after monitoring there is no errors appearing.?
But I'm affraid if that will affect the performance?
Is it OK to leave it half?
Half duplex is perfectly fine on a link where you are not expecting a lot of raw-throughput. The only time you will notice a performance difference is if you intend to do 80% or more bandwitdh (in 100mbps that is 8 Megabytes per second) each way simultaneously. you can do one way at 8, or two ways at 4. (Very roughly speaking).
For obvious reasons, full-duplex will give you up to 2x the bandwidth available because the bidirectional traffic is not sharing the bandwidth.
But when I configured the link with Half dublex I got lot of collisions and deferred and both are increased with average of hour monitoring? is it normal situation and have to believe it?
